Suspension Decision
Suspension Decision
I need help on what kind of suspension i should get for my 65 mustang. I know i want to do coil and not air. The car will be 100% street but i would still like to be able to corner great. I would like to be able to have the choice of going to the track and pulling good numbers and then driving home. This is all i know though after that i have no clue on suspension. I was wondering if i should get a kit like this http://www.cjponyparts.com/supreme-f...-1966/p/SUSK4/ or something like this http://www.cjponyparts.com/ron-morri...1966/p/SUSK60/ or just get a new front end like this http://www.cjponyparts.com/rod-and-c...3/p/RCK107P-V/ The last one looks best to me because i also want to convert to disc brakes and it looks like it would be the cheapest overall. What do i need to do the rear besides swapping in a 9 inch. Will someone please help me and show me some guidance.
I've just installed the Rod and Custom front end with coil overs, and it sits great!! No complaints. The car is still undergoing restoration, so I haven't driven it yet, but from what I can see and read, it's a pretty good set-up. I also went with the 2" drop spindles for it.
Oh, it doesn't come painted red (you have to do that on your own).
Can you put up some photos of your ride height please. I am either considering this setup or the TCI IRS setup. I was also wondering if a IFS would work fine with a live rear axle. I am wondering this because the only IRS i have found for a 65 mustang is the heidts and it is over 7500. Most solid rear axles i have found were less than 2K. I want to have a nice ride feeling but still be able to go to the track and thrash it around so would i really need a IRS to do that or could i just buy a good solid live rear axle.
For some reason, I can't post any attachments right now. I'll upload what pictures I have to a hosting site later tonight and go from there. I have a Heidt's 4-link rear bolt in that will be mated with my 9" rear end, on order and it will be here next Monday. I've ordered it from Mustangstofear.com From what my builder and from what I've read, a solid rear axle with an IFS works just fine. BUT, you may want to do your own research.
I don't have any real tracks around me where I live currently so I couldn't tell you right now but about 10s or 11s in the quarter mile would probably what I would be getting. I am going to most likely go with and independent front suspension and a solid rear axle. I have been in solid rear axle cars all my life so I would probably have to get used to a independent rear. I also have read that an independent rear would only have the advantage when cornering really hard and on a road that isn't perfect, which most tracks are perfect that I have read of at least. Also the independent rear I found for the 65 mustang is 4 times the amount of a solid live axle and I just don't want to pay that much.
I recommend the Ron Morris kit. You can either go with the ETI (easy to install) or the full coil over and tubular control arms setup if money allows. The quality of these parts is second to none and really works well. Not too mention the parts look great too. Just my .02. I have a ton of experience with these kits. What is your budget. There is also a really sweet coil over setup for the back that should be available within a couple months to compliment the front.
Matt's 95 Stang
10-05-2015 07:16 AM
