Posi trac in 8 in rear end
Old 05-19-2013, 07:05 PM
66$tang
66$tang's Avatar
Default Posi trac in 8 in rear end
I have a 66 mustang that i put a 347 stroker in a couple years ago, i put in a 8 in rear end. but without posi it really isnt as fun as it could be is there an easy way to put posi in. I dont want to replace the whole rear end but just replace the differential or whatever. any ideas or places to buy would be greatly appreciated. Thanks
66$tang is offline
Old 05-19-2013, 11:23 PM
rwcstang
rwcstang's Avatar
try ebays tj1141 "550hp 8 posi" he swears his differentials can withstand the power. and he has good feedback.
http://www.ebay.com/itm/FORD-EIGHT-INCH-REAR-END-MERCURY-COUGAR-OR-STREET-ROD-8-TRAC-LOC-POSI-550hp-9-/330921531623?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d0c75d8e7&vxp=mtr
rwcstang is offline
Old 05-20-2013, 12:05 AM
Gun Jam
Moderator
Gun Jam's Avatar
There is also the turetrac diffs I run an 8" one and I think they are awesome.
Im not sure on the max torque limit for the truetrac.
http://www.eaton.com/Eaton/ProductsS...als/PCT_221471
Gun Jam is offline
Old 05-20-2013, 06:30 AM
palerider
palerider's Avatar
Ive bought 2 off the person on ebay -had good experience both times
palerider is offline
Old 05-20-2013, 09:51 PM
imboden
imboden's Avatar
Had a shop drop a posi in my 8 inch rear end. works great. shopped it out to make sure it was done right. gear posi or clutch posi were my options, went with the clutch since I'm not gonna race the thing
imboden is offline
Old 05-21-2013, 11:19 AM
groho
groho's Avatar
8" traclocs are cheaper and lighter, and properly built, can withstand decent hp. If you have an automatic vs a manual, its even better. The sudden torgue of a manual is what destroys rear ends and breaks cases, where as automatics pre-load eliminating the sudden impact of hard start. I've gotta new 3:25 tracloc center section I picked up for $600 (?). Look around, you can get decent units for fairly cheap.
groho is offline
mtgldr
02-03-2024 09:00 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Dragonus18
09-09-2015 01:21 AM
robjh22
Suspension
09-08-2015 12:47 PM
09-08-2015 11:50 AM
Quick Reply: Posi trac in 8 in rear end
