mustang to comet
Old 06-14-2013, 08:08 PM
MonsterBilly
MonsterBilly's Avatar
Default mustang to comet
So i have been in the process of building a 65 mustang. However i found a smokin deal on a 65 comet. it is complete and nice other than no engine.
So i have decided to scrap the stang project and use the parts on the comet. How much of mustang parts will cross over?
rear end, is it the same width?
front suspension, I have all new mustang parts will they work on the comet? ie disc brake conversion, springs, control arms, steering parts.
steering column? can i put the mustang column in the comet?
motor mounts?
thanks guys..
MonsterBilly is offline
Old 06-14-2013, 10:55 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
pretty sure most everything will swap over the comet is just a mercury variant of the falcon and the mustang is based off of it
rmodel65 is offline
Old 06-15-2013, 05:17 AM
Al Newman
Al Newman's Avatar
The 1965 Comet engine bay is +-1" shorter and +- 1" narrower.
Brakes will transfer
Springs will not transfer correctly, even though they will fit.
Center link for the Comet is 1 5/8"+- shorter. The Mustang will NOT work because of this. Power steering setup is quite a bit different. Manual steering components other than the center link are the same.
Comet steering column gear box shaft is a bit longer than the Mustang, so the gear box won't work.
It's been a long time since I've messed with the Comets, but I believe they don't have a lower crossmember as do the Mustangs. The V8 Comet would greatly benefit from installing one.
If you will be retaining the column shifting setup in the Comet, you will have pretty good exhaust system challenges on the driver's side. The Comet exhaust manifold for column shifting is terrible flow-wise.
If the Comet is an original 6 cylinder, you will have challenges installing a V8 accelerator linkeage setup. The Comet uses a somewhat unique bellcrank setup at the rear of the intake that will be difficult to locate. The Mustang accelerator pedal and linkage setup can be used but with some interesting engineering. The Comet's firewall is the problem.
I was always a big fan of the Falson (essentially identical to the Comet), but, as can be seen above, they aren't for everybody. Good luck, and don't hesitate to ask if you have questions. I've made just about every mistake imaginable with your project.
Best,
Al
Mrmust@juno.com
Al Newman is offline
Old 06-15-2013, 07:25 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
Great poop, Al.
I always loved the old Comets.
fastbackford351 is offline
Old 06-15-2013, 08:49 AM
120mm
120mm's Avatar
Comets are just not done enough, imo.
120mm is offline
Old 06-15-2013, 07:39 PM
MonsterBilly
thank you. I will be hitting you up in the near future
Old 06-16-2013, 09:24 AM
69mach1377
69mach1377's Avatar
I had a 65 Comet 4 door in high school. It was turquoise with a white top and quite a chick magnet...not!
69mach1377 is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
01-06-2016 07:03 PM
chain
08-17-2015 08:52 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: mustang to comet
