347 Stroker vs 351W
Old 06-27-2013, 08:20 PM
67mustang302
67mustang302's Avatar
No one builds big blocks any more for factory cars. Technology lets small blocks make more power more efficiently. The only real reason for a big block these days is either nostalgia like was mentioned, or you just need a huge motor for a boat/drag car.
If you have access to one, you can make easy power with them. But the next guy with a similarly built small block will beat your ***. We live in an era where production small blocks are producing over 1,000hp in some cases, and these days over 400 is common from factory engines.
67mustang302 is offline
Old 06-28-2013, 05:01 PM
69mach1377
69mach1377's Avatar
The saying used to be, 'the cure for a small block is a big block', which is still true for a few applications.
Now the it would be something like, 'the cure for a small block is a big inch small block'.
69mach1377 is offline
Old 06-28-2013, 05:59 PM
67mustang302
Or a turbo. Or nitrous. Or a higher rpm small block.
If you have a big block laying around, most of them make decent power with little effort not because of their size, but BB head designs were WAY better until the head market for small blocks took off.
Not surprisingly, some of the newer small block heads carry over features from big block designs of yesteryear.
Old 06-29-2013, 10:02 AM
palerider
palerider's Avatar
How accessible are 351 rollers? Also if you are doing 65/66 302 better fit.
palerider is offline
Old 06-29-2013, 12:56 PM
67mustang302
Later 351 truck engines were roller blocks.
Old 06-29-2013, 07:09 PM
69mach1377
69mach1377's Avatar
Roller blocks are not required for a roller cam install. Just get the right cam and link bar lifters.
guitarman376
09-30-2015 05:54 PM
LiquidDrink
09-29-2015 10:06 AM
Brett Ludlow
09-23-2015 06:59 AM
EASTIDEE123
09-15-2015 11:08 AM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: 347 Stroker vs 351W
