Ideal voltage to positive side on coil when using points?
#21
Hello!
I have a old fashioned Mallory with dual points, Accel 1.4 ohms coil and 0.7 ballast resistor (and probably a wire resistance from the ignition).
I have 13 volt on battery and 14 volt when engine running. The results are:
With no resistor: 9 voltage on positive side on coil when running and 5.7 voltage when key on and motor off.
With resistor: 8 voltage on positive side on coil when running and 4.7 voltage when key on and motor off.
I had problems with the car shaking/dying during hot summer days and the results above were much worse when I used a 0.7 ohms MSD blaster so I changed to 1.4 Accel and they improved. Should I also skip the ballast resistor or not? Is 9 voltage to much? I do not want to burn the breaker points.
Now back to your question, if you are using the factory dist lead wire and the ballast resistor you are dropping more voltage than is necessary. ( as you've already noticed how low the voltage goes). Ideally 7-9 volts on the + side of the coil is plenty for a street car. You can also use a straight 12V-racers can use 12 V all day long to get the best performance but it takes special coils to do so. To close- look for a coil that is designed to run 12V and use it if you want the best performance. In the day, ACCEL were the ignition parts to use for best performance.
TfcCDR
09-14-2015 12:08 PM
