what size exhaust pipes
Old 08-15-2013, 01:03 PM
Jasonwayne222
Jasonwayne222's Avatar
Default what size exhaust pipes
I have a 302 with about 330hp 320torque. I have long tube headers and am about to buy a new exhaust system. I am thinking of getting a 2inch system with an hpipe. And using flowmaster 40s. Any suggestions
Also my headers are wrapped and do an excellent job of keeping in the heat. Will I gain anything other than appearance buy switching to ceramic coated headers.
Jasonwayne222 is offline
Old 08-15-2013, 01:15 PM
drunkyoda
drunkyoda's Avatar
i would think 2" is a little too small. with that much hp you gotta be pushing some air through there! so i would suggest 2.25" that way you keep your back pressure and dont lose tq but will also get better air flow to make some more hp up top.
drunkyoda is offline
Old 08-15-2013, 01:30 PM
1slow67
ROTM Moderator
1slow67's Avatar
I would do at least a 2.25" exhaust if not 2.5", 2" is too small to me.
1slow67 is offline
Old 08-15-2013, 01:34 PM
TexasAxMan
TexasAxMan's Avatar
K codes came with 2" pipes ...
TexasAxMan is offline
Old 08-15-2013, 02:02 PM
dawson1112
dawson1112's Avatar
scince you have long tubes I would go with 2.5" mid pipe and all the way back till the last 16 to 18" then use some 3" tips .
The long tubes provide plenty of torque and your not gonna loose that much by openin up the exhaust to 2.5" if any at all. The 3" tips will deepen the tone as it exists the tail pipes .
dawson1112 is offline
Old 08-15-2013, 03:28 PM
67mustang302
67mustang302's Avatar
2.5" is common, plenty of kits out there. Wrapped headers have a tendency to hold moisture in the wrapping and eventually corrode through, so ceramic helps there but are expensive.
67mustang302 is offline
Old 08-19-2013, 07:46 PM
frdnut
frdnut's Avatar
Minimum 2 1/2 for that setup.
frdnut is offline
Old 08-19-2013, 09:38 PM
LCC
LCC's Avatar
http://www.exhaustvideos.com/faq/how...pipe-diameter/
http://www.magnaflow.com/wideopen/performdata.asp
LCC is offline
Old 08-20-2013, 12:27 AM
TomKat
TomKat's Avatar
i run 2" Shelby gt350 glasspack side exhaust from tri-y. love the combo
TomKat is offline
Old 08-20-2013, 02:19 PM
Jasonwayne222
I think im goin with patriot ceramic coated long tube headers with 1 1/2 primaries 3" collectors with 2 1/4 tubing with an h-pipe and flowmaster 40s
Quick Reply: what size exhaust pipes
