Fuel Line Leak
Old 09-04-2013, 08:18 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
if that doesnt work and you have a compressor you can put air into the tank with a rag around it while someone turns the motor over. you dont need a lot of air(dont balloon the tank)
rmodel65 is offline
Old 09-10-2013, 04:09 PM
unit91
unit91's Avatar
New line arrived today. It's the stainless steel one. It needs to be bent some in order for it to be the correct shape. Think I need to heat it before I bend it?
unit91 is offline
Old 09-10-2013, 06:47 PM
Boogie's_AutoRama
Boogie's_AutoRama's Avatar
Don't heat it.
Message the bends it already has until it fits. Be careful not to kink it.
Boogie's_AutoRama is offline
Old 09-11-2013, 09:34 AM
unit91
unit91's Avatar
Roger. Thanks.
unit91 is offline
Old 09-11-2013, 09:03 PM
unit91
unit91's Avatar
OK, my engine is a 6 cyl 200 cu in. The OLD fuel line I'm replacing is 3/8 ". The NEW fuel line I bought is only 5/16 ". Is that gonna matter when it comes to harming the fuel pump, i.e. making it work harder to pump? I see in the NPD catalog that 5/16" was standard for my size engine, and the 3/8" is for V8s. Wonder why my fuel line was 3/8 " instead of 5/16"?
unit91 is offline
Old 09-11-2013, 09:10 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
no 3/8 is huge for a stock motor...5/16 will do you just fine.
rmodel65 is offline
StalkerGT
09-25-2015 02:41 PM
TfcCDR
09-14-2015 12:08 PM
tramphardrocker
09-13-2015 08:56 PM
MasterLanMan
09-13-2015 08:21 PM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: Fuel Line Leak
