?? about window adjustment and watershield adhesive
Old 09-07-2013, 02:24 PM
TexasAxMan
TexasAxMan's Avatar
Question ?? about window adjustment and watershield adhesive
I'm nearing completion on my '66!
I've got the windows installed and they work pretty well, but I'm having a fit adjusting them. Does anyone have any procedures I can follow to get this done?
Also, what is the stuff called that adheres the watershield to the inner door? And where do you get it?
Thanks in advance for any help.
TexasAxMan is offline
Old 09-07-2013, 02:42 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
fitting the windows is honestly trial and error...as for the black stuff its bedding and glazing compound 3m makes it most Napa's around here stock the stuff if they sell paint stuff
rmodel65 is offline
Old 09-07-2013, 02:47 PM
TexasAxMan
TexasAxMan's Avatar
Do I adjust vent wing first? That's the part I'm having "fun" with ...
Old 09-07-2013, 02:55 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
They say to measure where the wing is before you ever took it apart. I assume you didnt. But id definitely start there get a proper gap between the a pillar and the vent window then adjust the regulator etc
rmodel65 is offline
Old 09-07-2013, 10:39 PM
Iskwezm
Iskwezm's Avatar
what i have done in the past is adjust from inside the car,leave the adjustment bolts loose, close the door, roll the window up and then tighten and check the fit.
Iskwezm is offline
Old 09-09-2013, 07:15 PM
TexasAxMan
TexasAxMan's Avatar
Iskwezm, I'm gonna try that, thanks for the suggestion.
Old 09-11-2013, 11:12 AM
TexasAxMan
TexasAxMan's Avatar
What ended up working for me was to roll the window down and adjust the vent wing first, then loosen the side window adjustment bolts, roll it up and retighten the bolts.
cr620
10-03-2022 10:18 PM
jwog666
12-27-2021 08:09 PM
lincolnshibuya
07-05-2020 03:05 AM
UrS4
10-03-2015 06:23 AM
winner99
09-30-2015 07:04 PM
Quick Reply: ?? about window adjustment and watershield adhesive
