351 Cleveland timing marks on HB line up with my #5?????
Old 09-15-2013, 10:17 PM
Sparkiewalt
Sparkiewalt's Avatar
Default 351 Cleveland timing marks on HB line up with my #5?????
When I went to check the timing on my 1973 Grande 351 2V, I could not see the marks on my harmonic balancer as it passed the pointer, so I connected the timing light to the #5 cylinder and it lined up perfectly. I just replaced the timing chain and camshaft. I know that I installed the parts correctly. The engine cranks and runs perfectly. Is it possible I have the wrong HB on this motor?? any ideas why it is like this???
Sparkiewalt is offline
Old 09-15-2013, 10:54 PM
TexasAxMan
TexasAxMan's Avatar
I don't know the answer, sorry.
My first thought was that you were a GM guy, 'cause #1 on a GM is #5 on a Ford. It's funny that the firing order is the same if you convert the cylinder #'s...
TexasAxMan is offline
Old 09-16-2013, 07:42 AM
Sparkiewalt
well you are correct that I have been a GM guy with my hot rods. (Ford Trucks Rule) I got a 67 GTO. But this Mustang is for my son and I did check the firing order and ford starts at front passengers side and goes back to the firewall then crosses over making the #5 the front drivers side plug. I figure this has to be the wrong Harmonic balancer, but If I hook up to the #5 I can time it perfectly.
carid
07-08-2016 09:55 AM
musnicki
09-23-2015 07:11 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
mdj89
09-06-2015 11:08 PM
09-02-2015 08:40 PM
Quick Reply: 351 Cleveland timing marks on HB line up with my #5?????
