Advice on a 68 mustang purchase...
Hey guys,
This is my first time posting here.
It's been a looooong time since I have owned a mustang. My first car ever was a 1967 coupe. Later I picked up a 1969 Grande, restored it, and sold it. That was about 10 years ago.
Now I'm on the hunt for another.
I saw a solid project online. The ad says it is a 1968 289. Engine needs work/rebuild. Owner says tranny is good, based on previous owner's word. So at this point, who knows.
Needs a hood, some TLC in the interior, and body/paint work.
I know the pics aren't much to go off of. But I could really use some expert advice on what I should look for, based on what you can see from the pics. It's been a while since I have owned one, so I feel like a novice again.
Thanks in advance guys. I'm going to look at it tomorrow, so trying to arm myself with all the info I can.
well the biggest thing is to check for rust...if that car is solid id pay about 500-700$ for it. you should check the cowl, floor boards, trunk floor and all the other common areas
Concerning the engine, I wonder what would be the most cost effective route to get this thing running solid with decent performance? Should I just try and find a decent engine to swap in place of the current one? Like a 302 or 351w? I'm guessing a 5.0 EFI would come with too many added costs to swap in a budget.
LOLOL at 2k...id definitely pass like waffle said. for 5k you could get a really clean driver 65-68 coupe...
but cost effective id probably pick up an explorer motor from a 1996-1997 then add on the mustang oil pan, timing cover, intake and a distributor and ignition box from a 1985 GT(because its roller cam) and then an adapter flexplate for the 50 ounce balance
NorthAmericanTuning
03-18-2016 11:21 AM
