crown vic disc brake swap on 66 mustang
Old 09-17-2009, 09:24 AM
rebelbull
rebelbull's Avatar
Default crown vic disc brake swap on 66 mustang
I was wondering if i could put the crown vic disc brakes on my 1966 mustang i got 5 lug axles i saw somewhere that you needed a spacer
but will brakes fit and work good? what all do i need to take off of the vic?
is there any specific year range to look for or are all pretty much good?
thanks alot i hope to get them tommrow so hopefully ill get some post today
thanks again
rebelbull is offline
Old 09-17-2009, 06:17 PM
67 evil eleanor
67 evil eleanor's Avatar
Yeh..... the brackets are thick is where the spacer goes. "Moser" has a bearing that seals with an "O" ring that works without the need for a spacer (its like built onto the bearing). Be aware that some "Crown Vics" will fit and some not. The years I don't know. Also the caliper orentiation will vary as well as the E-brake may give you some trouble. Make sure your homework first.
67 evil eleanor is offline
Old 09-17-2009, 09:19 PM
2+2GT
2+2GT's Avatar
Ya know, the OEM type 65-66 disc brakes bolt on in a few hours, with simple hand tools. You could sleep late Saturday and still test drive before dinner.
2+2GT is offline
Old 09-17-2009, 09:57 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the mid 90s crown vics are what you need to look for
the police cars are the better setup with slotted rotors and different pistons in the caliper
as for making them work they are a bolt on on 8inch rear with a shim which you can find on ebay
rmodel65 is offline
Old 09-18-2009, 01:07 AM
tx65coupe
tx65coupe's Avatar
Now that you mention it, I just realized I don't hardly ever hear of anyone doing it.
How come nobody seems to put OEM type 65-66 disc brakes on when upgrading from 4 wheel drum?
tx65coupe is offline
Old 09-18-2009, 06:01 AM
67 evil eleanor
Sure the bolt ons are simple, but be prepared to pull out the green. It seems that they range from $600 to over a $1000. I have changed 3 of my cars over to Explorer's or Crown Vic's for less than $200 for all three, and will be doing a 4th by spring (freebie set). To answer your original post, yes, but then again, do your research before you start.
Old 09-18-2009, 06:30 AM
2+2GT
2+2GT's Avatar
Well, you can get disc brakes for 4-bolt Mustangs now.
Most people upgrading from 4 to 5 bolt are also converting to V8. I figure they are reading a lotta magazines in preparation, and said magazines, hoping to curry favor with their sponsors, recommend super-zoomy 14" slotted cross-drilled disc brakes with 12 piston calipers. Of course, for street driving such brakes are a waste of money, but if you are racing, or want to impress people with how much money you spent at cruise night, very useful.
2+2GT is offline
Old 09-18-2009, 10:40 PM
rebelbull
rebelbull's Avatar
Default not understanding
ok guys i was out at the wrecking yards today
i found a bunch of 92 and 94 crown vics with the rear discs
may sound stupid but im not sure what all im needing of it
obviously the calipers rotors but what else anyone have a pic of what i need or something i really wanna get them and for ten dollars a piece i think its a good idea
please help
thanks
Old 09-19-2009, 02:12 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
ok this is the kit you need to adapt, all the kit contains is the stuff to bolt on and shim the axles if you look around on yahoo google etc you can find the dimensions maybe get a machine shop to make some cheaper??
as for the parts take everything from the rear on each brake side, bracket calipers all bolts lines hoses etc if its hooked to the brakes take it with you
rmodel65 is offline
Old 09-21-2013, 06:23 PM
rcssr
rcssr's Avatar
I made the change on my 66 using 93 Crown Vic calipers and rotors. Bolts up fine but be aware that you need to change the distribution valve as well or you will do doughnuts the first time you throw out the anchor. I also have an issue with the front honeycomb wheels not clearing the calipers. My buddy used a grinding wheel on them to clear but I am not happy with that. I am going to look for a smaller caliper that will bolt on and clear those wheels. Standard steel wheels are not a problem
rcssr is offline
FD725
08-23-2015 06:43 AM
ding56
08-14-2015 02:40 AM
PearlGenPu
08-12-2015 01:57 PM
daytooday
08-11-2015 09:22 AM
FD725
08-11-2015 03:43 AM
Quick Reply: crown vic disc brake swap on 66 mustang
