sanding rust
RE: sanding rust
well...its not going all the way through...like on the fender along the edge (right before the headlight socket)....its not very deep but after sanding it a while its still leaving little dark traces...i dont know if these are bad or not...if they are should i keep sanding?
RE: sanding rust
ORIGINAL: 6mustang6
I'd keep sanding, but where the metal is being sanded, the scratches usually look dark. So make sure it's rust.
RE: sanding rust
Be sure to get a good metal prep on that after you're done sanding. You may also want to spray the sanded areas wioth one of those rust to primer converter sprays. I think it works chemically to stop the rusting process.
09-17-2015 07:57 PM
