Brake pedal travel
Old 10-23-2013, 12:31 PM
TexasAxMan
TexasAxMan's Avatar
Default Brake pedal travel
Now that my car is drivable, I don't like the way the brake pedal feels. It goes almost all the way to the floor, stopping about 1 1/2" from the floor. Gets very firm, but almost no braking until almost at the floor. It will barely lock the brakes, only at slow speeds.
I think they're bled properly. Any other possibilities?
TexasAxMan is offline
Old 10-23-2013, 02:39 PM
67mustang302
67mustang302's Avatar
They're either not bled, or you have a huge mismatch in master cylinder to caliper size.
What setup, and is the m/c new and was it bench bled?
67mustang302 is offline
Old 10-23-2013, 05:10 PM
69mach1377
69mach1377's Avatar
Or the linkage is incorrect. Manual or power brakes?
69mach1377 is offline
Old 10-24-2013, 12:19 PM
TexasAxMan
TexasAxMan's Avatar
Sorry, it is a manual CSRP Granada kit. I don't think there is any mismatch of parts.
The pedal is not soft at all, just seems to travel too far. I guess I'll bleed them again, for the fourth time.
Old 10-24-2013, 02:33 PM
clowe1965
clowe1965's Avatar
Possible expansion of the hoses as well? Mine does that too and its still all drums.
clowe1965 is offline
Old 10-24-2013, 02:42 PM
67mustang302
Well, traveling far isn't necessarily a problem, depends on the calipers and m/c. With a smaller bore m/c you build pressure more easily and have less leg effort, but have to push the pedal farther to move the needed volume. Many race cars have setups like that, where if it's manual the pedal goes almost to the floor.
Old 10-24-2013, 03:05 PM
jlg2002
jlg2002's Avatar
It can also be the brake adjustment if the backs (or fronts) are still drums. If not, along the same lines as 67mustang302 states-it's the amount of fluid required to engage the pad from pistons movement thru the caliper housing volume enough to stop. You should be running a disk brake MC if you didn't change it out. You may also adjust the MC input rod to engage the MC shuttle a little faster.
jlg2002 is offline
Old 10-24-2013, 04:56 PM
TexasAxMan
TexasAxMan's Avatar
There is some wiggle room before the pedal starts pushing the rod, maybe 1/4" of travel. It is rear drum. What is a good starting point for the proportioning valve, I think I have it set in the middle of its range ...
Old 10-24-2013, 05:57 PM
69mach1377
69mach1377's Avatar
Don't think there should be any wiggle room, it gets multplied by geometry.
Old 10-25-2013, 06:19 AM
Boogie's_AutoRama
Boogie's_AutoRama's Avatar
I have Granada brakes in mine with a (unknown) later model Ford master cyl.
Have quite a bit of brake pedal travel before they bite. But it does catch pretty far off the floor.
Adjusting the rear brakes helped a lot.
Brake rod is snug in the back of the mst cyl.
Boogie's_AutoRama is offline
Quick Reply: Brake pedal travel
