Engine Harness: less/more than standard
Old 10-31-2013, 11:13 PM
I-fly
I-fly's Avatar
Default Engine Harness: less/more than standard
hello, everyone
I'm working on an A code '66 coupe that i've been trying to restore for a long time. I'm down to figuring out how i'm gonna wire this bad boy's engine up, but electrical was never my thing.
These are the components i'm using:
-msd blaster 3 coil
-100 amp 1 wire alternator
-starter (type with solenoid mounted on it)
-ignition components (distributor, plugs, and wires are already in. i have that at least)
additional question-
where does the voltage regulator and fuse block fit in?
P.S. This is pretty much a rat rodded mustang, so as far as looking original goes, it's the least of my concerns) Any help is appreciated. Thanks in advance
I-fly is offline
Old 11-01-2013, 02:40 PM
jlg2002
jlg2002's Avatar
If you want the affected circuits designed from the ground up PM me and we'll talk about it. If you want to just modify the stock harnesses that's another story - not sure why you want fuses in the circuits described and no Vreg is req'd with a 1 wire alternator.
or
you can spend the money for the painless kits.
jlg2002 is offline
Nick Oliver
10-17-2018 04:22 AM
2007StangV6
01-28-2016 06:09 PM
showoffzx2
4 Cylinder NA and Turbo
09-14-2015 08:40 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Engine Harness: less/more than standard
