Best distributor ?!
Best distributor ?!
hi,
i am looking to buy a distributor for my engine. I have a fresh 289 rebuilt with 4 bbl performer intake. original autolite 4100 carb. What are you recommend fpr this engine ?
thanks for your help.
Mathieu
Mathieu
The "best" distributor is the stock one you already have, that has been professionally adjusted for ideal advance curves.
Distributor advance adjustment is probably the single most overlooked aspect of engine performance. I have adjusted many, and I have yet to put one on the machine and found it to be within limits. Ignore this at your peril; unless this is done, you may as well drive around with the carb float level set wrong, and all the spark plugs at different gaps.
This sounds fun.
If I wanted to find someone who could use this machine to set up a dizzy what would it be called? It is suitable for mech only distributors or is it designed for vac advance systems?
What about the all digital distributors like the MSD E curve???
-Gun
-Gun
Best depends on the setup. A stock distributor/ignition would never be able to properly power an 11.5:1 compression high specific power engine.
By the same token a monster race distributor is massive overkill for a stock 289.
hi,
what exactly is your goal?
is your eng stock, moderate or wild?
stock dist on stock or mild - moderate engs works fine. curving it for a modded eng as suggested is helpful.
the biggest bang for your buck imo is a high voltage msd solid coil and an msd ign box. the analog one was on sale at summit for only $110.00.
Thank for your time and help, i am a young guy who just buy this car 1 year a go for a restoration. I am new in this passion. I don't really good with mecanical. My goa with my car its to built a dayli driver with is original style but i want a good performance and torque !!
I agree with fastbackford351....I have a Duraspark system on my '65 289 and it's a LOT better than the old stock points-type ignition. I use a later model Ford TFI coil with it, and it produces a good spark with no need to check or set points,etc. Plus, replacement parts are at any local parts store. With the hotter spark, you can run a wider plug gap, too. I'm running Motorcraft BSF-42C plugs gapped at .050...fires right up and runs great....Go electronic!!
I've been unable to locate anyone in my area that has a distributor machine. The shops around here all adjust timing advance "by ear". You may find more luck if you're near a racing community.
Lastly, I'm not that familiar with the E curve, but my guess is that it electronically calculates the rpm and adjust the timing according to a pre-determined program. Thus not needing ajustment on a distributor machine.
Good luck.
Last edited by crunchyskippy; 01-16-2014 at 10:14 AM. Reason: Corrected a mis-statement.
