Fuel pressure reg to stablize fuel pressure??
Old 01-16-2014, 05:25 PM
  #21
kenash
kenash's Avatar
Hi,
I'm not a drag racer, but, what I've learned from guys it will "not pass" tech inspection. I'm don't know the reason though. Perhaps, a "voice of reason" will ring in.....
kenash is offline
Old 01-16-2014, 05:29 PM
  #22
Iskwezm
Iskwezm's Avatar
Originally Posted by BuckeyeDemon
is the firewall an acceptable place to mount a fuel pressure regulator and route fuel lines if you have plans to drag race (nhra rules)???
no you cannot have it mounted above the transmission. I didnt pass tech for that reason years ago.
Iskwezm is offline
Old 01-16-2014, 05:30 PM
  #23
BuckeyeDemon
BuckeyeDemon's Avatar
Originally Posted by kenash
Hi,
i believe the NHRA prohibits fuel lines from crossing the bellhousing area to reduce the chance of blown flywheel/flexplate cutting fuel lines
BuckeyeDemon is offline
Old 01-16-2014, 05:33 PM
  #24
Gun Jam
Moderator
Gun Jam's Avatar
The very fist step is to choose a proper hose size. 3/8 hose is what I was told to run and is currently what Im running now. So that would be the same as a 6/16th or -6AN fitting. Is this an acceptable size?
The aeroquip fuel line looks great but can I run any -6an fitting with it or are there some brands that must be avoided? are the summit brand an fittings okay to use?
Thanks
-Gun
Gun Jam is offline
Old 01-16-2014, 05:35 PM
  #25
kenash
kenash's Avatar
Thanks! A very good reason.
kenash is offline
Old 01-16-2014, 07:08 PM
  #26
67mustang302
67mustang302's Avatar
Line size depends on the power of the engine and it's efficiency and delivery pressure.
-6 is fine for most street engine carb setups.
67mustang302 is offline
Old 01-16-2014, 07:54 PM
  #27
kenash
kenash's Avatar
...and besides, it's all about delivery at WOT, wherein, line size and gph matter?
How many of us on the street live in the "WOT" zone, anymore.
kenash is offline
Old 01-16-2014, 09:21 PM
  #28
67mustang302
Except if you go wot getting on a road and run out of fuel, then your engine could get destroyed. 1 lean out at full power on a high performance engine could be all it takes.
Old 01-16-2014, 09:36 PM
  #29
kenash
kenash's Avatar
While I agree there can be a grenade effect, my preface is based on the GPH fuel consumption of a given engine and it's displacement. Given, a normal street prepared "hot" engine, they ain't run'n out of fuel at 6500Rs. Unless they are big cubes running 3/16" lines and very well prepared. Most fuel pumps would shut them down.
kenash is offline
Old 01-16-2014, 10:46 PM
  #30
67mustang302
It depends on the setup. A 600hp turbo engine consumes substantially more fuel than a 600hp n/a engine. RPM doesn't matter, only power and bsfc.
Quick Reply: Fuel pressure reg to stablize fuel pressure??
