1966 Coupe Drum to Disc Brake Conversion
Yes, you will have to replace the m/c, change the distribution block (or add an in-line prop valve), and replumb some hard lines. Most kits come with a new m/c, but the hard lines can be purchased at any parts store.
I have the OE-style CSRP disc kit without the booster. I did it initially to save a couple bucks, with the knowledge that I could always add a booster down the road if I felt I needed it. But after driving it for a while as a manual setup, I'm very happy with it. It's leaps and bounds better than the original manual drum brakes, and I don't ever find myself wishing that I had a power booster.
Power brakes are good for a lazy weekend car, or maybe a daily that you wanted to be as easy to drive as possible. But they make modulating the brakes difficult during performance driving, as brake assist varies with engine vacuum.
CSRP has a factory-style combo block that has a proportioning valve built in, eliminating the need for an in-line prop valve for the rear brakes. Makes for a cleaner look, and also means you don't have to cut and re-flare the rear brake line.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
