where should I install the fan t-stat switch
I bought a electric fan and a wiring kit with a relay and 185* thermo switch,
however, I have no place to install the temp switch. I am thinking about just hooking it up to a keyed fuse. I know the fan will be on as long as the key is on but I do live In AZ so I don't think it will hurt.
Is there another option that is clean and functional.
thanks
B
thanks
B
yes that is the type of switch it uses.
I had to switch to the electric fan because I switched to a serpentine set up and do not have enough room between it and the aftermarket radiator to fit a conventional fan. So I had to switch to a front mount push style electric fan.
And since I frequently drive the car on 100* plus days I was thinking that it always being on would not be an issue.
Well, puller fans tend to work better, so hopefully you won't have issues in extreme heat. Are the intake bungs full? What about the thermostat housing? If you don't have one, you can get a thermostat housing with a threaded bung for senders, and just install the switch there.
I'm not sure if such a beast exists.
That's handled by EFI though, the temp sender tells the temp, and the ECU just reads the temp info to power a relay. In that case the ECU is an external unit that controls the fan.
To have a sender that did both, you'd need a sender with a built in switch at a set point. I've never seen one.
