tire recommendations
A "true" (for lack of a better phrase) drag radial (Mickey Thompson ET Street, etc.) might not be something you want to daily drive on if wet roads/rain are anything more than a rare occurrence where you live (they can be a bit scary in wet freeway conditions, plus they won't last at all tread-wise if the 'stang is your daily).
How wide are your rear rims, and what size 555r are you currently running out back?
There's a limit to how much traction you can have from a practical standpoint. 3 or 4 link suspensions really help with forward bite, but on a street tire with a lot of power, there's only so much you can do. One of the reasons new performance cars have traction control systems.
Keep in mind that a softer tire that provides better traction in warm weather, tends to perform more poorly in cold weather, and rain (when the roads get cold). A lot of the summer tires with good traction, suck dick once the temps get under 50*. Road condition has a lot to do with it as well, most roads have mediocre condition which will limit traction.
I'm in AZ where I rarely see temps below 50*. I have 17x8 wheels and the widest tire I can run is 245. I have Cal tracs but man i can't hook up. My problem is not off the line , it's once I'm rolling. If i get on it hard in 2nd and 3rd i end up 2 lanes over and sideways
You can put a 275/40/17 drag radial on depending on your wheel offset. I used them for a few years and when i took them off they still had tread left.But i have buddies that usem on daily drivers and get about 15-20K miles out of them.
jwog666
12-27-2021 08:09 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
