Heat or ground? (starting issue)
Old 02-02-2014, 08:13 PM
teej
teej's Avatar
Default Heat or ground? (starting issue)
Hi - 67 fastback with a new alternator, MSD ignition, relatively new battery.
When cold - starts no problem.
Drive for 20 minutes, park, then try to start and the engine barely turns over, won't spark to start. If I wait a few minutes it will turn over a few more times but still no spark. 13V at the battery when in this situation. If I boost the battery, even with a portable 1500 AMP battery booster, it will start.
Ideas?
Starter or solenoid heat soak?
Bad ground? (coil, ignition, ? )
thanks.
teej is offline
Old 02-02-2014, 10:25 PM
Gun Jam
Moderator
Gun Jam's Avatar
when did it last work right?
-Gun
Gun Jam is offline
Old 02-03-2014, 01:51 AM
teej
teej's Avatar
-Gun
Its been a while. Had issues with the power, had a lag on throttle so moved up to msd ignition. Sometime after that, not right away, started having the issue.
I run a single wire alternator. The voltage was low so just swapped it with new. That didn't fix the situation so I know its not the charging system. Has to be either starter or the battery or a ground issue, my guess. I could be wrong though, thats why I thought I would ask here.
teej is offline
Old 02-03-2014, 04:10 PM
Gun Jam
Moderator
Gun Jam's Avatar
what starter are you using? is it a mini starter for a t5 trans or is it the big original one?
also put a volt meter on the battery and crank it over when hot have someone watch and see what the voltage sag looks like when the starter is attempting to engage.
What is your current timing set to initial?
-Gun
Gun Jam is offline
Old 02-09-2014, 01:44 PM
teej
teej's Avatar
the voltage sags to 8V when it tries to start. I swapped the starter solenoid with a spare to make sure it wasn't the culprit - same issue. So I am guessing starter - ?
teej is offline
Old 02-09-2014, 01:55 PM
racer_dave
racer_dave's Avatar
sounds like starter to me. It's pulling too many amps.
racer_dave is offline
Old 02-09-2014, 05:49 PM
Gun Jam
Moderator
Gun Jam's Avatar
sounds like a bad battery to me.
I suggest having the battery tested first then if it test good perhaps look into a cause for high starter resistance.
-Gun
Gun Jam is offline
Old 02-09-2014, 07:55 PM
creaky
creaky's Avatar
-Gun
+1..........when the battery voltage drops below 9.5 volts during starting, the battery is going south.
creaky is offline
Old 02-09-2014, 10:51 PM
MonsterBilly
MonsterBilly's Avatar
FYI i had a similar issue with a spanking new starter. THen I replaced it, Same issue. returned that one and have been good since.
MonsterBilly is offline
Old 02-11-2014, 03:54 PM
69mach1377
69mach1377's Avatar
I've got a similar issue, but I think the starter is getting too hot from the header.
69mach1377 is offline
djbigskrilla
09-20-2022 01:04 AM
Calizic
08-28-2015 01:46 PM
jpplaw
08-22-2015 09:29 PM
overnight89
08-22-2015 09:02 PM
jdphillips73
08-16-2015 04:34 PM
Quick Reply: Heat or ground? (starting issue)
