Radiator going bad? (pics)
Old 02-23-2014, 10:29 PM
Jbomb
Jbomb's Avatar
Default Radiator going bad? (pics)
So i park in an underground garage so lighting isn't that great and never noticed this before. While taking pics of the engine bay then looking at the pics i saw the radiator wasn't looking so hot. I do leak a little bit of radiator fluid but not much What do you guys think?
Looking up the part number it seems to be a scott drake 3-row radiator
Jbomb is offline
Old 02-23-2014, 11:07 PM
Starfury
Starfury's Avatar
Quite possibly. Looks like a seam leak to me. A lot of the chain parts stores will let you "rent" (buy and then return w/in 48hrs) a radiator pressure tester. Grab one and see where it's leaking from.
Starfury is offline
Old 02-24-2014, 06:17 AM
Boogie's_AutoRama
Boogie's_AutoRama's Avatar
There's no need to test it. ...it's leaking from the seam.
A radiator shop should be able to repair it.
Check into that first. But for what they may want to repair it, for a few bucks more you could get a brand new one off eBay.
http://www.ebay.com/sch/i.html?_saca...skc=1000&rt=nc
Boogie's_AutoRama is offline
Old 02-24-2014, 06:27 AM
creaky
creaky's Avatar
I bought a new 3 row radiator online from Advance Auto, $86 with the discount coupon code, looks a whole lot like the original.
creaky is offline
Old 02-24-2014, 10:08 PM
Jbomb
Jbomb's Avatar
can you post a link creaky? thanks
Jbomb is offline
Old 02-25-2014, 05:18 AM
creaky
creaky's Avatar
Here you are, link to the ad and link to the coupon code. The pricing shown is for my local store, don't know if that would be the same in your neck of the woods or not.
http://shop.advanceautoparts.com/web...&storeId=10151
http://promocodesforyou.com/index.ph...FbQWMgodQ08AvQ
creaky is offline
Old 03-05-2014, 07:32 AM
Diputado
Diputado's Avatar
Ok...I see the real problem....look at that sticker on the radiator. What does that say?....."Made in China".
I was also having radiator issues with my '65. I went with a Champion 4-core all-aluminum radiator (Made in USA)...problem solved. Sure, a little more expensive than those Autozone,etc. Chinese radiators..but worth it!
Diputado is offline
Old 03-11-2014, 02:09 PM
Jbomb
Jbomb's Avatar
whats the difference between radiators for manual vs automatic? all the aluminum radiators with e-fan on ebay i see say "manual only"
Jbomb is offline
Old 03-11-2014, 06:53 PM
90RunnerRed
90RunnerRed's Avatar
The manual only doesn't have the transmission cooler built in. Easy to differentiate, just look for the two coolant line hookups at the bottom of the radiator between the petcock and the lower hose port. The picture below shows one with the trans cooler. I just bought one of the champion/e fan combos off ebay with the shroud, well worth the money.
90RunnerRed is offline
Old 03-11-2014, 09:16 PM
Jbomb
Jbomb's Avatar
Thanks Runner
okay this one on ebay says manual only, those little red caps non removeable?
Jbomb is offline
Quick Reply: Radiator going bad? (pics)
