loose shifter
loose shifter
I have just acquired a 67 mustang coupe to fix up and sell. the only thing really wrong aside from a good paint rub is the auto shifter. it is really loose and floppy. it has a console which I removed to see if I could find /fix the problem. the nut that holds the shifter handle was as tight as it would be. so I took it off to see what was what. it appears that there might be a bushing of sorts either missing or worn. I can't get the handle to come off to see. I need some help. is there a parts break down for this? and how do you get the shifter off? any advice would be most appreciated. thanks
You can get this bushing kit for $6.95 and it should take care of it -
http://www.mustangsunlimited.com/ite...p?T1=F1104R+01
Most Mustang vendors have them for about the same price
loose ****er
I have the same exact problem. Is your plate which tells you what position its in taken off? The one that says P-R-N-D, if it is that is your problem!!! Mine was loose as could be with the plate of and sturdy with it on because it can no longer go sideways.
http://www.npdlink.com/store/product...05947-421.html
Here you go -
http://www.mustangsunlimited.com/itemdy00.asp?T1=94N+01
junior04
09-28-2015 10:53 AM
