Radiator Support Weatherstrip
Old 03-03-2014, 02:50 PM
genec728
genec728's Avatar
Default Radiator Support Weatherstrip
My 66 convertible was missing the rubber weather stripping that mounts on top of the radiator support when I got it. I bought one and it came with small staples. How do I mount this thing using these small staples thru the steel radiator support. I guess I could drill holes and use small bolts unless some of you have a better idea. Thanks
genec728 is offline
Old 03-03-2014, 04:18 PM
skip3535
skip3535's Avatar
Default staples
If you look at the support you can probably see were the staples were. I pushed the rubber on the support and used a scribe or nail and pushed it up from the bottom thru the rubber on top. Then you can push the staple thru. Then push down on top of staple and fold the bottom of staple over. I never attached the bottom of the seal and this seems to be working fine. This can be a bit difficult. good luck
skip3535 is offline
Granatelli Sales
01-20-2020 12:34 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
MusicCity615
09-12-2015 07:05 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Radiator Support Weatherstrip
