motor feedback
Old 04-11-2014, 10:14 PM
kenash
kenash's Avatar
Originally Posted by barnett468
yes, good info. you can also sneak in another .5 compression using aluminum heads.
Yep! Ditto brother Barnette468....
My ride (s)....
kenash is offline
Old 04-16-2014, 10:24 AM
groho
groho's Avatar
thanks for the feedback, measured specs, and put data into the summit compression calculator and come up with a 9.7CR which is right in line with my objectives. This is not changing anything the rotating assembly, cuz its not necessary since this is a recent rebuild by the PO, bearing/rod and bearing/cap clearances check at .012, and cam bearings look nearly unused. I need to use a hipo head gasket to achieve this CR. Unless I can find better the thinnest I can find is .039 using a 351W head gasket from felpro. I'd like to see a .035-037 if possible, can anyone suggest something? The rearend will remain a 3:25 tracloc, but intend to change to a 3:73 if I can locate a gearvendor O/D. It's much cheaper to drop in a G/V than upgrading the entire tranmission assembly to a built AOD or 5-speed.
groho is offline
Old 04-16-2014, 02:36 PM
kenash
kenash's Avatar
Hi,
Why would you want to tighten the quench that much? Running iron heads together with a tighter quench is going to increase your detonation factor.
Can I ask what are the numbers you used and how did you determine them in arriving at the 9.7 CR?
kenash is offline
Old 04-16-2014, 04:37 PM
groho
groho's Avatar
I won't be running iron heads, I'll be running AFR165, 58CC. the specs were, 3.5" stroke, 4.030 bore, .047 piston to deck clearance, +8cc valve relief pistons, 58cc heads, .039 heads gasket = 9.71:1 CR
groho is offline
Old 04-16-2014, 05:33 PM
kenash
kenash's Avatar
OK, looks like you got the right numbers going on. The reason I thought your were running iron heads was your reference to 351 head gaskets. But, your choice in heads is a good one. I run a similar setup, but, am running a 10.6 CR static. Did you CC the piston reliefs or take what the mfg. stated? The reason I asked, I run Probes and they were not what was listed by them. So, I CC'd all of them. Also know the area between the top of 1st ring and the top of the piston is a couple of CCs. I believe it was 2 CCs in my case. There is a CR calculator that will provide your dynamic CR through the input of the opening and closing events of your cam.
I've since forgotten this, but, there is a minimum "quench" that you will want to maintain. I might have it somewhere in original assembly sheets.
Good Luck....
kenash is offline
firehorse02
11-16-2015 11:28 AM
Matt's 95 Stang
10-05-2015 07:16 AM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
logan409
09-26-2015 07:43 PM
Quick Reply: motor feedback
