69 Mach 1 suspension and brake upgrade
So I'm working on a frame up restoration on a 69 Mach 1 I just bought and I'm not sure on a lot of aspects. First problem comes in with the suspension/breaking upgrade.
I'm not looking to do any road racing but I would like to go fast and I'm not the type to half *** a project so I've been looking into the Heidts IFS system in the front. I'd like to go a little cheaper in the rear but still get a good upgrade. I'm looking to squat the whole car, 2" in the front and 1" in the rear. I can get the 2" in the front with the drop spindles and the 1" in the rear with mid eye leafs.
My question comes in with the spring ratings I should go with front and back. If anyone has any better ideas I'm all ears, thanks for the help.
I think most here will agree that this will be sufficient for you:
disc brake conversion
shelby drop
new control arms/ strut rods
roller perches
subframe connectors
good shocks
4.5 or 5 leaf springs with mid or reverse eye
monte carlo bar
overhaul steering or borgeson conversion
nice alignment per ORP's specs
I am nearly finished rebuilding my 69's steering and suspension. However, I was looking to take turns as my primary goal. Here's my setup
ORP roller track arms upper and lower
ORP double roller perches
560lb 1" drop springs with 1 coil cut
1" sway bar front
street or track solid strut rods
1.5" shelby drop
monte carlo brace
gas a just in front, stock shocks rear
4.5 reverse eye leafs
70' spindles
street or tracks older 13" sn95 cobra brake conversion (stops on a dime!)
tinman subframe connectors are soon to be added
Spring ratings are figured out for you if you stay with stock style suspension. Let me know if you have any questions, I know these front ends well now!
shelby drop
roller perches
subframe connectors
good shocks
monte carlo bar
1" sway bar front
1.5" shelby drop
monte carlo brace
70' spindles
mungodrums
10-07-2015 04:01 AM
musnicki
09-23-2015 07:11 AM
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
