Lowering springs RAISED my ride height, suggestions?
Old 04-10-2014, 06:06 PM
ian8950
ian8950's Avatar
Default Lowering springs RAISED my ride height, suggestions?
I have a 1969 Fastback and I recently purchased 1'' lowering springs for the front end to have it sit a little lower than the back end. However after installing them I see that the front end now sits about a half inch higher than before. I knew this could happen as the front springs were original and were pretty worn in. I was wondering the best way to get the lowered front end look that I wanted... should I;
1. remove the springs and cut an inch of height off them
2. get the "shelby drop"
3. do something else.
Any suggestions/opinions are welcome please.
ian8950 is offline
Old 04-10-2014, 07:39 PM
rwcstang
rwcstang's Avatar
what part of California? if you're in the bay area, I can give the shelby drop Template if you need it.
also, is the spring sitting on the perches correctly? usually with aftermarket lowering springs ppl would have to cut the spring to get the desired height. also post pics.
rwcstang is offline
Old 04-10-2014, 07:57 PM
barnett468
barnett468's Avatar
easy deal, what springs are they exactly.
typically, if you cut 1/3 of a coil it will drop 1".
barnett468 is offline
Old 04-11-2014, 10:39 AM
Starfury
Starfury's Avatar
I would do roller perches and the Shelby drop (since you have to remove the springs anyway), which may drop the front 3/8" or so. Then cut 1/4 coil at a time to achieve the desired ride height.
Starfury is offline
Old 04-12-2014, 01:29 PM
boogerschnot
boogerschnot's Avatar
Agree with all of the above.. do the shelby drop, and cut the springs 1/4 turn
at a time
boogerschnot is offline
mtgldr
02-03-2024 09:00 PM
PullTab
10-30-2015 08:46 AM
Pyrate Dave
09-10-2015 07:30 PM
Sparks_88
09-08-2015 01:06 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Lowering springs RAISED my ride height, suggestions?
