New headlights for 66...which ones?
Old 04-13-2014, 11:22 PM
Gun Jam
Moderator
Gun Jam's Avatar
Default New headlights for 66...which ones?
I picked up a rock and it center punched the DS headlight.
For a 66 is there a brand or type of headlight that is awesome and since im changing headlights I should pick up?
Thanks
-Gun
Gun Jam is offline
Old 04-14-2014, 12:51 AM
barnett468
barnett468's Avatar
hello;
what is a ds headlite?
if you want fancy lites you can buy tri bar clear flat glass halogen lites.
barnett468 is offline
Old 04-14-2014, 01:04 AM
Gun Jam
Moderator
Gun Jam's Avatar
Drivers Side...my bad
Im more concerned about actual performance...There are lots of different lights out there Im hoping someone can vouch for a specific one that they thought really kicked ***. As in good brightness, good light pattern over all good quality.
Thanks again
-Gun
Gun Jam is offline
Old 04-14-2014, 06:37 AM
barnett468
barnett468's Avatar
hi;
well i've used a couple and they worked fine but unfortunately i hate halogens so i'm a bad person to ask and i don't want to recommend something you might not like since the're kinda pricy. someone here should have a suggestion for you though.
Old 04-14-2014, 12:06 PM
Gun Jam
Moderator
Gun Jam's Avatar
You ran HID?
Gun Jam is offline
Old 04-14-2014, 04:43 PM
Starfury
Starfury's Avatar
I like my Wagner BriteLite bulbs. Sylvania XtraVisions are equivalent. They offer a slightly brighter/wider beam than stock and seem to work fine for me.
Rewiring the headlights to run through a relay as opposed to putting all the power through the HL switch is a good idea as well. I haven't done it yet myself, but it removes a lot of the resistance from the stock wiring, providing full charging voltage to the headlights.
Starfury is offline
Old 04-14-2014, 11:08 PM
MonsterBilly
MonsterBilly's Avatar
I wired my lights via relay and it made a huge diff. It was easy and cheap.
I also picked up a set of lights with LED halos that I like. They are a little faggy but I like them.
I use the sylvania build and they are really bright.
I did not like the tri bars. they have glass lenses that are weak. one little pebble and they shatter. I went through 3 in the first year I had my car on the road here in the desert.
MonsterBilly is offline
Old 04-14-2014, 11:57 PM
Gun Jam
Moderator
Gun Jam's Avatar
Cool
Thanks for the tips
While I see the value of relay I want to steer clear of this for now...I consider them a failure point...
I'll look into the above options!
-Gun
Gun Jam is offline
Old 04-15-2014, 09:15 AM
Starfury
Starfury's Avatar
You realize that the stock system runs all of the power through the HL switch, right? That makes the HL switch a failure point. Patching a relay into the wiring significantly cuts down on the power going through the HL switch, putting all of the power through the relay. Just make sure to get a good relay and you'll be fine. I'd rather change an easily-accessible relay than the HL switch any day.
Starfury is offline
Old 04-15-2014, 11:14 AM
Gun Jam
Moderator
Gun Jam's Avatar
Yes.
The HL switch has run without fail for about 50 years. Add a relay now I have HL switch and relay to fail
The relays in a Porsche I sometimes drive that cost 35,000 new in 88 fail once and a while.
The HL relay on my buddies diesel truck took crap after about 4 years.
That said there will come a day when I switch to a relay system...but today is not that day
Gun Jam is offline
Quick Reply: New headlights for 66...which ones?
