issues with c6 transmission in my 67 mustang
Okay so I started it up with the tires off the ground. I take it out of park and the tires seem to spin the same direction no matter what gear the shifter is in, including reverse. But with very weak force. Is this because there is just not enough hydraulic pressure to work thru the gears?
I started the car with the transmission cooler line pointing towards a bucket, it definitely is pumping out but it's pumping pretty darn slow, like I could stop the pressure with my thumb and let it build pressure against my thumb.
Oh yeah, there are no metal shavings I'm the fluid at all.
Any ideas from here? I'm about to drain it to check the filter now
AmericanMuscle4.6GT
11-10-2015 02:06 PM
LivingInThePast
09-16-2015 12:20 PM
