Edelbrock carb with throttle lever kit HELP!!!
Old 04-21-2014, 12:15 AM
ggfits
ggfits's Avatar
Default Edelbrock carb with throttle lever kit HELP!!!
Having a hard time trying to connect the linkage.
Has anyone used this throttle lever #1483 and how did you hook it up.
Here is a pic of mine.
thanx,
george
Attached Thumbnails Edelbrock carb with throttle lever kit HELP!!!-carb-throttle-kit.jpg
ggfits is offline
Old 04-21-2014, 12:19 AM
ggfits
ggfits's Avatar
[IMG] imgur[/IMG]
ggfits is offline
Old 04-21-2014, 02:30 AM
barnett468
barnett468's Avatar
yeah, buy the bushing below, install it and make sure your throttle opens all the way when the pedal is on the floow and the pedal will be just abit even with the brake pedal then. drill a hole near the end of the rod for a cotter pin and install a washer under the pin.
you should have bought a holley.
http://www.carbsonly.com/carbs/bushing.htm
barnett468 is offline
Old 04-21-2014, 06:50 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
Check this out.
JamesW turned me on to this when I was doing the throttle rod dick dance. It looks great, works great and is butter smooth and is a nice upgrade over factory.
http://www.fordmuscle.com/archives/2...kage/index.php
It's an article that breaks it all down. I already had the brake line laying around and I bought the rest at Lowes for about $10.00 or so.
fastbackford351 is offline
Old 04-24-2014, 09:40 PM
ggfits
ggfits's Avatar
@barnett468 Thanx, I'll give that a try.
@fastbackford351 Thanx, that does look good. When I have more time I will have to do this one.
Thanx again guys!
ggfits is offline
Old 04-25-2014, 08:03 AM
racer_dave
racer_dave's Avatar
Hey, I use this one on the racecars. It has everything in it, rod, heims, bushings, screws & locknuts. Yes it $30, but it saves me a trip to the store (plus I buy enough from Lane to get free shipping). Longacre and Allstar make them as well. Summit, Speedway, Jegs, Lane, Pitstopusa, Motor State all carry them. For me its easier to get everything at once than cob it together.
http://pitstopusa.com/i-5084754-joes...-assembly.html
racer_dave is offline
Old 04-25-2014, 01:40 PM
bop11
bop11's Avatar
Make sure that that center part is not nylon! Nylon is hygroscopic, absorbs water and swells. Ford used it back in the '60's in the carb as the throttle plate rod bearings. A lot of carbs stuck open because the nylon swelled and grabbed the throttle pivot rod not letting it return because the spring was too weak. Big recall if I remember on Falcons due to this.
bop11 is offline
Old 04-25-2014, 02:37 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Yep, make sure the bushing is Delrin (acetal). It's not hygroscopic after it's been molded and also withstands heat better. Most places will call them hi-temp bushings or Delrin bushing.
Derf00 is offline
uberstang1
09-20-2015 06:42 PM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
Wombatnation
09-13-2015 09:16 PM
tramphardrocker
09-13-2015 08:56 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Edelbrock carb with throttle lever kit HELP!!!
