Saginaw to 351w!
Old 05-08-2014, 05:56 PM
guitarman376
guitarman376's Avatar
Default Saginaw to 351w!
Hi everyone,
I'm getting ready to order parts for the borgeson power steering setup. Borgeson uses a GM Saginaw P series style power steering pump in their kit. However Borgeson seems to have modified/manufactured their own version of the saginaw p pump, which connects to the Borgeson mount from behind.
This is different from typical p series saginaw pumps, which typically mount from the front just behind the pulley. I don't want to be forced into buying a power steering pump from Borgeson in the future if a replacement is needed, and it would be so much easier if a standard front mount style pump can be used.
Does anyone make a front-style saginaw mount that will work with the standard crank pulley v belt setup on a 69 351w? Obviously I don't want to have to start changing pulley sizes anywhere!
I found this, but it requires different crank pulley etc
http://www.ebay.com/itm/Ford-289-302-351W-Saginaw-Power-Steering-Bracket-Billet-Aluminum-SBF-/121132552769?pt=Vintage_Car_Truck_Parts_Accessories&hash=item1c34101241&vxp=mtr
Then there are mounts like this (apparently made by borgeson)
http://www.ebay.com/itm/Ford-289-302-351W-Saginaw-Style-Pump-Power-Steering-Brackets-/111036782560?pt=Motors_Car_Truck_Parts_Accessories&hash=item19da4ed7e0&vxp=mtr
I actually emailed borgeson asking them if the mount kit above would mount a stock style p series pump to an otherwise stock 69 351w, and they didn't reply... almost as if they don't want to lose a sale. Does anyone know or have experience mounting standard saginaw pumps to SBFs?
Some of you may wonder why I am trying to avoid buying everything from borgeson and the answer is simple. Down the line, the more parts I can just get at a parts store the more money I save. That being said, if Borgeson is the only company that makes a compatible pump/mount setup for a v belt 69 351w I guess I am constrained.
Anybody have experience with this stuff?
guitarman376 is offline
Old 05-14-2014, 12:17 AM
guitarman376
Well I decided to just buy the complete kit from borgeson (pump, mount, hoses, box, rag joint). Stay tuned as I will be updating my main thread in the next few weeks to start phase II of my project.
guitarman376
09-30-2015 05:54 PM
LiquidDrink
09-29-2015 10:06 AM
Mustang88LXKid
02-29-2004 08:01 PM
WNDSOR
01-30-2004 09:47 AM
Qwikpony
01-16-2004 12:45 AM
Quick Reply: Saginaw to 351w!
