Wireless Engine Bay
Old 06-04-2014, 02:08 PM
jonahdeich
jonahdeich's Avatar
Default Wireless Engine Bay
I recently found a beautiful picture of an engine bay where there were no wires visible whatsoever. I decided to try this wireless look on one the the mustangs I am restoring and need some help. These are the questions I have any suggestions for were to place wires would be awesome. I will start with a battery relocation kit and put it in the trunk.
1. Where do I put the starter solenoid?
2. I have a 6al box installed with an msd right now should I scrap it and get a different ignition or can I relocate and were to?
3. Does anyone know of a good battery relocation kit
4. Can wires be ran outside the engine bay?
Any help would be great and if you have an idea of were to hide a wire please tell me.
jonahdeich is offline
Old 06-04-2014, 02:41 PM
ajzride
ajzride's Avatar
Get a starter with the solenoid built in.
yep, run them in the fender well.
Look into a one wire alternator.
ajzride is offline
Old 06-04-2014, 02:43 PM
TexasAxMan
TexasAxMan's Avatar
I ran all my wires under the driver side fender. All that is visible in the engine compartment is a single feed containing the coil, water temp and oil pressure switch wires. I did not put the battery in the trunk though. If you put the solenoid in the trunk along with the battery, the cable will not be powered all the time, if you keep it in the engine bay, the cable is hot it's full length. Just some food for thought.
TexasAxMan is offline
Nick Oliver
10-17-2018 04:22 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
rksnow1
09-14-2015 08:46 PM
showoffzx2
4 Cylinder NA and Turbo
09-14-2015 08:40 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Wireless Engine Bay
