which spark plugs should I be running
Old 06-11-2014, 03:40 PM
MonsterBilly
MonsterBilly's Avatar
Default which spark plugs should I be running
I have a 331 stroker with trick flow aluminum heads and a stealth intake with an MSD ignition and distributor.
I run pump gas and it's about 10 to 1 compression and a live in the desert so my car runs pretty hot Already
MonsterBilly is offline
Old 06-12-2014, 09:25 AM
barnett468
barnett468's Avatar
the last numbe on the plug is the heat range you should have a 4 for stock you can try a 3 do not use champions. . plugs wont help a ton you need cooling improvements.
barnett468 is offline
Old 06-12-2014, 09:28 AM
Starfury
Starfury's Avatar
Trick Flow recommends Autolite 3924's, which is what I run in my 331. No problems so far. Are you having problems with your existing plugs?
Starfury is offline
Old 06-12-2014, 03:56 PM
67mustang302
67mustang302's Avatar
Autolite 3924 is about right. A 3 might be too cool, you'll know if you get deposits on the plug that don't burn off.
And yeah, plugs aren't the solution to a hot environment, cooling system is. Plugs deal with the engine build itself, hot enough to burn deposits off, without being so hot you get pre-ignition.
67mustang302 is offline
Old 06-12-2014, 04:52 PM
MonsterBilly
thank you, Im not changing plugs for temperature. I just wanted to include as much info as possible.
just doing a little work to the car and wanted to be sure to get the correct plugs.
Granatelli Sales
03-25-2016 08:01 PM
2007StangV6
01-28-2016 06:09 PM
Granatelli Sales
12-27-2015 06:28 PM
Mobiusone stang
09-07-2015 08:46 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: which spark plugs should I be running
