overflow tank
Old 06-18-2014, 08:51 PM
my68
my68's Avatar
Default overflow tank
i have a 67 mustang convertible want to install one of the expansion tanks for the radiator, it is one of the tube one, there is two ports on the bottom, i know one is for the overflow hose from the radiator what is the other one for thank you
my68 is offline
Old 06-19-2014, 08:32 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
A drain in case it overheats. I have a rubber hose on the second nipple that routes the overflow to the ground.
Pave the Earth.
fastbackford351 is offline
Old 06-19-2014, 10:04 AM
Built351Cleaver
Built351Cleaver's Avatar
You should be able to look straight through the top of your overflow (if it has a cap) and see that one of the pipes is longer than the other. The longer pipe allows fluid to drain out of said pipe if the pressure builds up high enough. Just grab a 9/32s hose and tie it so it drains under the car and doesn't get on anything potentially hot.
Built351Cleaver is offline
Old 06-19-2014, 10:14 AM
barnett468
barnett468's Avatar
you should not need one if your system cools properly and you have a 14 lb rad cap. but as mentioned one is the overflow for the overflow. . i guess you could use a second tank for that one if need be.
barnett468 is offline
Old 06-19-2014, 07:10 PM
Starfury
Starfury's Avatar
It's always nice to have a little bit of leeway with your coolant level. I have heat soak issues in the summer; after I shut the car down, the coolant tends to bubble over into the overflow. It's nice to know I have a reservoir to reclaim it.
Starfury is offline
Old 06-20-2014, 01:52 PM
my68
my68's Avatar
Default radiator overflow
thanks everyone for the information, my car doesn't run hot but i travel long distances to car show, i feel a little safer with it on
my68 is offline
Old 06-26-2014, 07:11 AM
Al Newman
Al Newman's Avatar
Actually, the big boys tell me that if you run the radiator top tank about 1" down from completely full, you won't have any shut down boil over issues. The overflow tank has never solved any overheating issues that I have encountered. My radiator guy said that running an oem tank completely full does not give the system any expansion room, and that causes the overflow tank to catch boil-over. Potential damage to the radiator is always a possibility, also, especially if the cap is not correct or decides not to release coolant. Personal experience does not suggest running the radiator down 1" either helps or hinders cooling; in addition, as stated, the overflow tank does not seem to allow the system to run cooler, either.
Best,
Al
Al Newman is offline
4cylinderplus2
10-09-2020 07:45 PM
Granatelli Sales
01-20-2020 12:34 AM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: overflow tank
