C4 transmission fluid coming out breather line
Old 06-24-2014, 11:17 PM
bradleyb
bradleyb's Avatar
Default C4 transmission fluid coming out breather line
Hi
I have a 66 mustang coupe with a C4 transmission with transgo shift kit, 302 engine, Edelbrock intake with Holly street avenger carb.
My problem is that I noticed transmission fluid shooting out of the breather line onto the intake in the back of the engine - when I measure using the dipstick at running temp, the fluid level looks ok. It also shifts and runs ok. Why is the fluid coming out of the open breather line (goes from vacuum modulator through hose and hard line to top of engine compartment in the back)???
Thanks in advance for your input!
Bradley
bradleyb is offline
Old 06-25-2014, 06:19 AM
Boogie's_AutoRama
Boogie's_AutoRama's Avatar
The only way I figure trans fluid can get into the intake system is thru the vacuum modulator.
Vacuum mod must be leaking fluid.
Boogie's_AutoRama is offline
Old 07-18-2014, 10:00 PM
bradleyb
bradleyb's Avatar
I have a rubber line that goes to a hard metal line that leads to the top of the engine compartment - I thought it was a breather line but fluid is coming up through that.
Would the vacuum modulator cause that?
bradleyb is offline
Old 07-19-2014, 12:44 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the vacuum modulator is on the trans. if the diaphragm ruptures you can suck transmission fluid thru the line
rmodel65 is offline
Old 07-22-2014, 10:19 PM
bradleyb
bradleyb's Avatar
If it ruptures will it still run properly? Mine runs great
bradleyb is offline
Old 08-02-2014, 02:39 AM
bradleyb
bradleyb's Avatar
rmodel, do you think it would suck the fluid from the transmission up the metal line to the top of the engine compartment?
bradleyb is offline
Old 08-02-2014, 08:19 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
yes you would have an active leak+vacuum= atf being sucked into the engine
rmodel65 is offline
drfister
05-03-2018 10:38 PM
KinneyD
01-09-2016 05:33 PM
inyadreems
08-21-2015 09:10 AM
Greyshot
08-15-2015 03:32 AM
Quick Reply: C4 transmission fluid coming out breather line
