help.new engine and nothing lines up
Old 07-13-2014, 08:33 PM
68gt/cs
68gt/cs's Avatar
Default help.new engine and nothing lines up
balancer mounting surface for pully is 4-7/8". old 68 302 is under 4".allready bought a/c, p.s.,alt., brackets for 68 302. new timing cover is for 68 302. also would like pass. [right] side inlet for water pump if possable {except inlet will cover timing marks on right side of balancer}. how screwed am i ? what parts do i need ? please help
68gt/cs is offline
Old 07-14-2014, 05:37 PM
groho
groho's Avatar
if you had pictures it would help allot in this type of scenario. There's many variables, you have 3 bolt harmonic balancers for early SBF, and 4 bolt balancers for later. You also have different long nose, short nose water pumps. I've been working on my 68 302, the stock set up is a three bolt 28 oz balancer.
groho is offline
Old 07-14-2014, 10:19 PM
Starfury
Starfury's Avatar
Where did you get this motor?
Starfury is offline
Old 07-15-2014, 05:07 PM
68gt/cs
68gt/cs's Avatar
crank is an eagle 0 balance w/a 4 bolt balancer. mounting surface for pully is 4-7/8" from block. i may have to buy all new mounting brackets for accesseries. what i need to know is what water pump [maybe left inlet], pullys, and do i need to change timing cover also. changing brackets is ok. ford makes alot of spacers for crank pully. did not think this would be so hard. asked summit for the rite parts-no help there.
68gt/cs is offline
Old 07-16-2014, 02:20 AM
boogerschnot
boogerschnot's Avatar
Like Tad asked... Where did you get the motor? Year and make of the motor will help us help you, did you have it built for you?
boogerschnot is offline
Old 07-16-2014, 11:09 AM
68gt/cs
68gt/cs's Avatar
did research. possibly 1970 timing cover and balancer style. found 3 lengths of water pumps, 10 differant crank pulleys, 5 water pump pulleys. cant afFORD march kit. off to pick a part.
68gt/cs is offline
Old 07-16-2014, 02:08 PM
Starfury
Starfury's Avatar
At this point, I'd recommend picking up a new timing cover and water pump to match the accessories you already have. Changing just the water pump will likely result in the timing mark being obscured, making it impossible to time the motor.
From there, you can pick up proper pulleys to match the timing cover and water pump. No need for a March kit.
I also just noticed you mentioned a zero-balanced crank. Ford small block cranks are supposed to be externally balanced (28oz for early motors), which will match your balancer and flywheel/flexplate. If for some reason you actually do have an internally balanced crankshaft, it will tear itself apart if you don't have a matching zero-balance flywheel and balancer.
Starfury is offline
Nick Oliver
10-17-2018 04:22 AM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
vintageaion
09-08-2015 10:45 AM
Quick Reply: help.new engine and nothing lines up
