302 Questions - Page 2 - MustangForums.com
Old 08-13-2014, 10:45 PM   #11
67mustang302
Quote:
Originally Posted by rmodel65 View Post
i dunno if you can swap heads on the tbird motor without doing piston mods. the 86 mustangs have a different piston compared to the 1985 and 1987-1993 engines.
It will depend on the heads and cam. Head with bigger valves and a cam with certain timing can result in issues.
67mustang302 is offline   Reply With Quote
Old 08-24-2014, 05:21 PM   #12
BDodson5.0
Update. As I thought but was ignoring, pulled the heads valves weren't seating properly. Game over for now. So time to get really starter. Metal work, suspension, interior, and motor build.
I'm trying to get a real parts list together so I can start buying parts. After pulling the heads, the rotating assembly seems mint. No scoring on the cylinder walls, rotates so easily without those clogged valves.
Plans were a set of 185cc AFR Heads like suggested. After all the research and comments and reviews I see on them its too hard to pass up. It also seems everyone like the Lunati Voodoo cam to go with it? Hearing tons of good reviews on these as well. Just wondering what the different size chambers mean and what the difference in the cams are. I'm looking at the street version, and the only difference I see is 300 rpm in the power band, is this correct?
I'll be pairing all of this with either my 600cfm holley carb or ill go up to a 750 if needed. Already have hooker long tubes and a pro comp manifold. Motor is going to a friend who builds motors and is specialty is ford sb's. It'll get forged internals, and a built crank. Just want to make sure my top end will produce.
Any help is greatly appreciated.
BDodson5.0 is offline   Reply With Quote
Old 08-24-2014, 09:14 PM   #13
barnett468
HELLO;
we need to know the following?
what ci do you want?
mild, moderate or brough idle?
tire warmer or tire roaster?
lite to lite drag car, freeway flier or inbetween?
roller or std cam?
barnett468 is offline   Reply With Quote
4 Valve Head questions GimpyHSHS 4.6L (1996-2004 Modular) Mustang 6 10-01-2015 10:01 AM
GT500 front LCA question UrS4 S197 Handling Section 1 09-30-2015 11:13 AM
cost to rebuild heads Drastang 4.6L (1996-2004 Modular) Mustang 2 09-30-2015 04:48 AM
Hello, new user with an older Mustang and a question treesloth New Member Area 4 09-28-2015 08:03 AM
