Ford Racing Z Heads
Old 08-10-2014, 09:54 PM
stillridin
stillridin's Avatar
Default Ford Racing Z Heads
Does any one have any experience or knowledge with these heads? Good? Bad?302/351W "Z-HEAD" ALUMINUM - ASSEMBLED 63CCM-6049-Z304DA*
stillridin is offline
Old 08-10-2014, 11:05 PM
67mustang302
67mustang302's Avatar
They're ok, but for the money you're much better off with AFR or TFS. You'll also get much better performance out of those than the Z head.
67mustang302 is offline
Old 08-11-2014, 12:18 AM
barnett468
barnett468's Avatar
hello;
it depends completely on the application. they are perfect for some apps but not perfect for others. it would help if you told us exactly what engine they are going on and cam size and intake type and rear gear ratio and desired type of performance.
the afr and tw brand of heads mentioned are killer.
edelbrock makes a nice affordable set that flow around 25% more than a set of stock heads. the afr 165's and tw 170's flow more than the eddy heads, however, bigger is not always better.
check these out
http://www.edelbrock.com/automotive/...treet-sb.shtml
barnett468 is offline
Old 09-11-2014, 10:41 PM
stillridin
stillridin's Avatar
sb 427 twin Precision Turbos .82 a/r 57-62mm. PT 5858cea's
cam lift int/exh 640
int 109 252
exh 119 244
Not sure on the intake. I'll call Holly and see what they recommend. I want to do their Dominator EFI. 327 gears. Weekend driver, sometimes track 1/8 and 1/4> Still got a long way to go but i'm piecing it together. These heads are brand new and half price.
Old 09-11-2014, 11:25 PM
barnett468
barnett468's Avatar
int 109 252
exh 119 244
depends on you goal but if you turbo it. they will be ok. the flow similar to the AFR 185 heads.
if you want a monster then but afr 205's but it will have a bit less bottom end.
they may require special headers because they have a raised ex port.
the car will be a pig with 3.23 gears.
JonnyBlazeGT
11-03-2015 01:10 AM
squishbang
Suspension
11-02-2015 03:42 PM
squishbang
09-07-2015 07:57 PM
ccwebb
08-11-2015 06:47 PM
mustangfan305
08-07-2015 11:09 AM
Quick Reply: Ford Racing Z Heads
