65' 9" rear end
Old 08-24-2014, 09:49 PM
lucasp
lucasp's Avatar
Default 65' 9" rear end
Where can i purchase a 9" rear end that will drop right in my 65' without any modification.
thank you,
lucasp is offline
Old 08-25-2014, 01:46 AM
barnett468
barnett468's Avatar
thank you,
http://currieenterprises2.reachlocal.net/
barnett468 is offline
Old 08-25-2014, 10:09 AM
Starfury
Starfury's Avatar
Yeah, you're really limited with those 65-66 models. The only cars that came with proper width 9" rears were 65-66 Mustangs with 9" rears (and possibly Falcons and Comets of the same year).
It's easier to get one from Currie, but probably cheaper to get one out of a truck and have it cut down for you.
Starfury is offline
Old 08-25-2014, 12:21 PM
67mustang302
67mustang302's Avatar
If you plan on doing road racing, auto cross or any serious cornering, especially with a non floating rear disc brake, then I'd recommend going with a Speedway Engineering floater rear end. You can get a built to fit full floating rear axle set up for not too much more than a Currie setup.
http://www.1speedway.com/Floater_Rear_Ends.htm
Otherwise, Currie.
67mustang302 is offline
Old 08-25-2014, 02:29 PM
RC65
RC65's Avatar
57 Ford
RC65 is offline
Old 08-26-2014, 04:36 AM
Al Newman
Al Newman's Avatar
Look for a mid-70' Granada with a 351W motor. It will have a 9" that will fit under your Mustang with no changes. It does have larger center hubs on the axle shafts and larger center hole in the brake drum. Aftermarket wheels generally will fit without issue, but original rims will not. If you want to retain original rims, simply use the axle shafts and drums from your existing 8". They will fit into the Granada housing without modifications.
Best,
Al
Al Newman is offline
Old 08-27-2014, 01:41 PM
Mickey94577
Mickey94577's Avatar
I got mine from quickperformance.com made to order and drop in.
Mickey94577 is offline
Old 08-30-2014, 12:57 PM
dogger1952
dogger1952's Avatar
thank you,
I have a 9inch NCasing PIG Center Section
dogger1952 is offline
Old 08-31-2014, 06:37 PM
dodgestang
dodgestang's Avatar
Got my current brand new housing on ebay
dodgestang is offline
Old 08-31-2014, 08:46 PM
barnett468
barnett468's Avatar
Best,
Al
isn't this going to be 1 1/2" wider than his 66 and not have tapered down tubes on the end so he will also need to run different lower shock mounting brackets?
mtgldr
02-03-2024 09:00 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
fastbackford351
09-12-2015 09:42 AM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: 65' 9" rear end
