Getting beat up by air cleaners...help
Old 10-20-2014, 11:19 AM
  #31
kalli
kalli's Avatar
i'll make a better one if you like. or if you need me to measure anything let me know. The filter sits on top of a 2121 intake with 1@ spacer and the very front hits the hood. you can see where it scraped the front off the aircleaner. it rubbed against the crossbar in hood,but the export brace was no problem. if you have the straight type then Id say not a hope
Attached Thumbnails Getting beat up by air cleaners...help-20140831_115614_richtone-hdr-.jpg
kalli is offline
Old 10-21-2014, 11:57 PM
  #32
Gun Jam
Moderator
Gun Jam's Avatar
Dang dude where have you been?
That picture is helpful! is that the scott drake export brace?
-Gun
Gun Jam is offline
Old 10-22-2014, 06:34 AM
  #33
kalli
kalli's Avatar
I'm on my way to child two, so I'm keeping busy. this forums is so full of good info, I don't know how/why I stayed away for so long.
that's the part number I bought: 29432-2B (you'll find a coupe of sellers googling for it) but not sure if it's Scott Drake. But I think that bent is only made for this single specific reason , to fit around the oval air cleaner. I'll get a couple of pics and measurements tonight so you can crosscheck.
kalli is offline
Old 10-22-2014, 10:29 AM
  #34
Gun Jam
Moderator
Gun Jam's Avatar
my MC bar is bent it in my case is required to clear the distributor...for some reason the MSD E curves seem to fit extra tall
Gun Jam is offline
Old 10-23-2014, 02:42 AM
  #35
tx65coupe
tx65coupe's Avatar
I've been a way from the forums for a while myself. I am not quite sure why either. Congrats on the new family member.
tx65coupe is offline
Old 10-23-2014, 02:43 AM
  #36
tx65coupe
tx65coupe's Avatar
If you need a new curved monte carlo bar, I do recommend the Scott Drake one. Its a nice part.
Old 10-23-2014, 02:53 AM
  #37
barnett468
barnett468's Avatar
I was super excited about these but I dont think it will fit. Its going to run into my export brace.
ummm Gun...are you now saying the Shelby filter will hit your Monte Carlo/Rallye bar and not your export brace?
If this is the case, we all could have helped you weeks ago. All Monte Carlo/Rallye bars have about the same bend.
barnett468 is offline
Old 10-24-2014, 10:59 AM
  #38
Gun Jam
Moderator
Gun Jam's Avatar
maybe I measured wrong or the screw hole isn't in the center
Gun Jam is offline
Old 10-25-2014, 04:07 AM
  #39
barnett468
barnett468's Avatar
the screw hole on the origs and for racing ones if around 1" from center. it only mounts in one direction and when mounted, it has around 1" of clearance from the shock tower brace so the short end of the cleaner goes to the rear. they sometimes hit aftermarket distributors if the dist is taller than stock. i use a 5.00 carb spacer if this happens but it makes the air cleaner a bit wobbly.
Old 10-27-2014, 02:37 PM
  #40
kalli
kalli's Avatar
actually a lot less room back there than you'd expect. So if you measured, I can understand why you said it won't fit. there's about half inch between the filter housing and the export brace. due to the fact that i use that specific intake with spacer, the brace is at the same height as the filter (cleaning element). so I gain another half inch. pretty tight back there. and from looking at barnetts picture it seems identical to mine (distances from what i can tell from that angle)
kalli is offline
Quick Reply: Getting beat up by air cleaners...help
