T10 question shifter loose
Old 03-22-2015, 05:05 PM
66_grn_fstbk
66_grn_fstbk's Avatar
Default T10 question shifter loose
HI all
I just purchased a 69 convertible to add to my stable. It is in pretty rough shape and the original I6 3spd was replaced by a 351C and a 4spd T10. The clutch needs an adjustment and I probably need to ensure that the linkage is adjusted properly, but the shifter flops around pretty badly, literally sits to one side when the boot is not in place. I cant imagine that this is the normal slack in the shifter. Can anyone provide any suggestions, adjustments etc. That would be useful. Or is it time to get a hurst shifter and be done with it.
thanks
christian
66_grn_fstbk is offline
Old 03-22-2015, 05:35 PM
barnett468
barnett468's Avatar
need to know exactly what shifter it is.
does the shifter have spring pressure if you push it directly sideways?
barnett468 is offline
Old 03-22-2015, 06:43 PM
66_grn_fstbk
thanks for the help. Dont know which shifter it is. I have taken a cell phone video of it. it is zipped but just so that that it can be uploaded.
thanks
christian
File Type: zip
Old 03-23-2015, 01:00 AM
barnett468
barnett468's Avatar
thanks
christian
sorry, im not a computer guy . . i have no idea how to open it . . you can download it on youtube.com and post the link here if you want.
there is no name on the side?
Old 03-23-2015, 10:07 AM
Starfury
Starfury's Avatar
I am a computer guy, and I have no idea what a .gp3 file is. Pictures are a little easier to work with.
Starfury is offline
Old 03-23-2015, 03:24 PM
barnett468
barnett468's Avatar
Old 03-23-2015, 10:28 PM
66_grn_fstbk
Hi all
thanks for trying to help!!! I published it at
gp3 files are from android phones pictures wouldnt capture the movement
thanks
christian
Old 03-24-2015, 10:27 AM
Starfury
Starfury's Avatar
Ah, that would explain it. I'm an iphone guy.
That's a factory ford shifter, and it's easily rebuilt. Pick up a 4sp shifter rebuild kit from Glazier's Mustang Barn. It's essentially some springs and replacement bushings. You'll have to get under the car to disconnect the linkage and remove the shifter, but overall it's not a very complicated job.
While you're at it, I'd recommend making sure you have a lower shift boot (often times the lower boots are removed during service). If you don't, order one of those as well. Also, grease up the shifter with some white lithium grease before reassembly.
Starfury is offline
Old 03-24-2015, 03:47 PM
barnett468
barnett468's Avatar
ok screw the bushings . . dont really need em . . remove a bolt . . go to the hardware store and buy 4 hardened flat washers that fit over the large part of the shaft . . put 2 washers on each bolt . . remove old bushings . . install bolts and shifter . . you're done.
Old 03-24-2015, 08:57 PM
66_grn_fstbk
thanks both-
Will do. It seems simple enough... i mean what could possibly go wrong.. its not like starting a small project like this has any chance of snowballing into something major!
cheers
christian
Quick Reply: T10 question shifter loose
