what the hey hey is this?
Old 03-26-2015, 09:58 PM
66_grn_fstbk
66_grn_fstbk's Avatar
Default what the hey hey is this?
So below is a pic from below the passenger side hood hinge in my new 69 'vert.. there are two tubes going into the apron... and there is some little round box that can be seen under the fender well. the arrow points to it.
thanks everyone.. this 69 will be very different than my green 66 fastbak
66_grn_fstbk is offline
Old 03-26-2015, 10:30 PM
Mustangdemon67
Mustangdemon67's Avatar
Where do the other ends of those tubes go? Maybe something vacuum related
Mustangdemon67 is offline
Old 03-26-2015, 10:48 PM
Shoelessjoe75
Shoelessjoe75's Avatar
Do you have a tilt away steering column? Might be for the vacuum canister for that and the A/C. Some 67's have the canister there.
Shoelessjoe75 is offline
Old 03-26-2015, 10:52 PM
66_grn_fstbk
had/has ac connections... no tilt steering wheel. I will chase it , but sounds like the ac.
Old 03-27-2015, 06:36 AM
Boogie's_AutoRama
Boogie's_AutoRama's Avatar
It's for the vacuum reservoir.
Boogie's_AutoRama is offline
Old 03-27-2015, 07:32 PM
barnett468
barnett468's Avatar
they go to a vac can inside the wheel well that operates the vacuum vents inside the car . . most are usually bad and very expensive...good luck.
barnett468 is offline
Old 03-28-2015, 06:36 PM
66_grn_fstbk
thanks all- Will probably remove the vacuum set up and go with a vintage air unit. It wiill simplify the underdash and it aint that expensive.
cheers\
GimpyHSHS
19
12-19-2023 01:12 PM
Coyote_hpr
11-12-2019 12:44 PM
Thunderball
15
11-22-2015 11:49 PM
dalehunter
09-25-2015 10:51 AM
Ghost_Conscience
09-23-2015 02:17 PM
Quick Reply: what the hey hey is this?
