1968 Notchback with 1994 GT motor
Yes...that said, if you're going to use the EFI from the donor, I'd strongly recommend looking for an 89-93 donor vehicle. 94-95 Mustangs are...different. The block is the same, but things like accessories and intake are different.
But if you're just looking for a 5.0 long block and want to carburate it and throw on v-belt accessories, the '94 donor will work.
what exactly do you plan to do . . you can get engines from explorers also and some have gt40 heads . . you can add gt40 upper intakes to 95 thru 97 explorer lowers.
http://www.fiveohinfo.com/performanc...early-explorer
logan409
09-26-2015 07:43 PM
