Intake and Carb Swap
#43
Ok so I think summit either sent me the wrong intake or their application charts are wrong, because I checked before I ordered and just checked again. There are 2 more bolts per side on the oe intake than there are on my new one.
Edelbrocks website even shows it as correct with the same intake I have!
http://www.edelbrock.com/automotive/...-rpm-289.shtml
<a href="http://s411.photobucket.com/user/guitarman376/media/150525_002.jpg.html" target="_blank"><img src="http://i411.photobucket.com/albums/pp195/guitarman376/150525_002.jpg" border="0" alt=" photo 150525_002.jpg"/></a>
<a href="http://s411.photobucket.com/user/guitarman376/media/150525_004.jpg.html" target="_blank"><img src="http://i411.photobucket.com/albums/pp195/guitarman376/150525_004.jpg" border="0" alt=" photo 150525_004.jpg"/></a>
Googling now...help
Googling now...help
#47
#49
If you look under 351w you'll see what I'm talking about.
The new intakes don't have as many bolts as the old one because they don't need to anymore. I guess gaskets got better, but it says right there will work fine with 16 bolt heads with a 16 bolt intake gasket
#50
I read that inserting brass female fittings into the intake ports (1 for water temp sensor, one for manifold vacuum, and one for heater hose) will prevent the fluid/vacuum fittings from seizing in the aluminum threads. Is this something I should do? It does seem like a good idea to me... If so, how do I determine the thread sizing of each?
