Rear axle upgrade
Rear axle upgrade
I have a 65 with 2.80:1 ratio 8" rear. I want to upgrade the gears. Suggestions of what I should do and why.
1. Upgrade pumpkin to 4:11.
2. Swap rear for 8.8" rear. (what is a good swap: requires very little modification/fabrication?)
3. Other suggestions?
Thanks
Thanks
my main question is Is it better to swap entire rear end for a 9" or just to replace the pumpkin with the gears that i want? I have a 4 speed manual but thats all i know about it. That i will upgrade.
I have realized 4.11 is a little agressive for what i want. it will be street highway driven. i dont plan on racing it. i found that with a 0.63 5th gear and 3.80 rear i can get get 70 mph at 2200 rpm or 2000rpm with 3.55.
it is a 5 lug
it is a 5 lug
Its easier/cheaper to just change the gears. It isn't hard to do, but you have to be comfortable doing the mechanical stuff. I'd swap to a track loc diff as well since it will be apart. Sure a 9" is a lot stronger, but the 8" is fine for most street cars, even if they've had some HP increase in the engine.
Foghorn Leghorn
Location: I reside in a near constant state of amazment.
I kept my 8" and recently ditched my factory peg leg 2.80's and installed a 3.26 tracloc setup and I couldn't be happier. It didn't kill the highway cruising with excessive rpms but gave a nice additional low end boost.
The best part is now I can lay two strips of rubber instead of only one and looking like the loner with the boner.
An 8.8" is a good upgrade for a 67-68 car (and possibly 69-70?) because the width is just about perfect. Anything else will require some engineering to get it to fit properly. Since you have a '65, if you were going to swap I'd just recommend a 9".
Thanks, I think im going to this route. I have already found a 3.80 with trutrac that I think I will purchase.
11-10-2015 11:39 AM
Dragonus18
09-09-2015 01:21 AM
M3hunter
09-05-2015 03:42 PM
