Four Speed Manual - Shifter Question
Old 06-29-2015, 11:39 AM
JES0860
JES0860's Avatar
Default Four Speed Manual - Shifter Question
Hi all,
I am new to Mustangs and to this forum.
I just bought a 1969 Mustang Coupe for my wife, with a Windsor 4V 351 and 4 speed manual transmission. It still has the original shifter.
On this shifter, Reverse is down and to the left (next to 2nd). There is no reverse lock out in the handle. With reverse placed next to 2nd gear, it seems like it would be easy to go from 1st right into reverse.
I have seen reverse up and to the left (next to first) which is out of the flow of the shifting. That makes sense to me. This pattern is new to me, and I certainly don't want to twist up a drive shaft.
1) Is there a reverse lock out built into this shifter?
2) If not, is there a good aftermarket shifter that you can recommend?
I certainly want to keep this car as stock as possible, but I consider this a safety issue for both me and the car!
Thanks,
Jay
This is the pattern. No reverse lock out on the shifter handle. Is it built in?
JES0860 is offline
Old 06-30-2015, 06:20 AM
Boogie's_AutoRama
Boogie's_AutoRama's Avatar
I don't think it is possible to shift into reverse with the car rolling forward.
Boogie's_AutoRama is offline
Old 06-30-2015, 09:34 AM
69mach1377
69mach1377's Avatar
IIRC, you'd have purposely ignore the loud grinding noises and muscle thru it. This has been true for decades.
69mach1377 is offline
Old 06-30-2015, 09:47 AM
JES0860
JES0860's Avatar
Thanks to all! Believe it or not, knowing that there will be a loud grinding noise is very comforting to me.
JES0860 is offline
Old 06-30-2015, 03:13 PM
69mach1377
69mach1377's Avatar
Sleep well...lol
Old 07-01-2015, 10:43 PM
Starfury
Starfury's Avatar
Yeah, having reverse over there isn't that big of a problem. It's a much more frustrating issue on something like a T56 where reverse is way over on the top right, which makes hunting for 5th interesting if you're in a hurry.
Starfury is offline
Old 07-06-2015, 02:59 PM
bop11
bop11's Avatar
There should be extra spring force in the shifter to make yo aware of reverse.
bop11 is offline
carid
07-08-2016 09:55 AM
musnicki
09-23-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
Roush05
09-10-2015 12:23 PM
Quick Reply: Four Speed Manual - Shifter Question
