HOT starting issues 351W
#21
okay, so more issues. when hot i have to turn the key for a second no gas. if i turn for longer it wont start. got smoke out exhaust nasty smelling too. carb issue? too rich? odd on quick turn over. something else must be at play.
#22
Okay, I just went to start it cold, took a couple cranks. then turned off and restarted it. THen off again then tried and let it crank a few more times then the strater didn't turn over.
I get the throw out sound , one click and not multiple like low battery, then lights dim out like a power drain.
Then a little smell, I open the hood and the solenoid was hot at the battery and starter posts (spit sizzle hot) and the cables were hot.
Is it a bad solenoid or another issue? what causes this?
wow, getting worse
wow, getting worse
#23
wow, getting worse
wow, getting worse
#24
You may have a blown head gasket and are filling a cylinder with coolant. You can get hydrolok if the leak has gotten big enough. This would lock the engine from turning causing a very high current drain on the starter when that cylinder comes up to compression. The leak may only happen with the engine hot. Check the antifreeze level and the oil level to insure antifreeze hasn't gone down and oil level has not increased.
#25
I had a hot start issue a couple years ago. Similar to your new problem. I ended up replacing the starter. After 3 auto zone started I got one at Napa and have not Han an issue since.
Your initial problem though may be timing. If the dist is too advanced then it may cause a hot start problem.
#26
Sounds like your starter just died.
If the solenoid overheats it usually means the starter is shorted internally.
#28
Okay, blown head gasket and anit in the cyl, scary.
I did replace the starter and solenoid(cause it was $15 and now shiny )
All is great, way better cranking and easy to start. Now I need to test a hot start today.
If the issue is there, I am then going to get a timing light and check that out
Stay tuned.....
Stay tuned.....
#29
#30
if the floats too high, it will start hard when hot, its that simple.
if you live where it does not snow, you can plug the exhaust heat crossover in the intake.
you can also get a thin phenolic spacer for the carb.
