Want To lower my Mustang 1" in rear and maybe 1 1/2" in front
Old 07-30-2015, 08:53 PM
Mustangs of Illinois
Mustangs of Illinois's Avatar
Thumbs up Lowered my Mustang 1" in rear and 1 1/4" in front
Well I changed the title to this as I have lowered the Mustang.
Put 1" lowering blocks in the rear and cut 1-5/8" coil off bottom of front springs. I had to modify my center spring tool to work in reverse, as there is no center hole for the rod to go down thru when the spring compresses. So I made it so the rod comes up thru the center access hole to do it.
Had to knock the center lips of the fender wells in, but still need to do it a little more. It looks 100% better than it did !
Mustangs of Illinois is offline
Old 07-30-2015, 08:54 PM
Old 07-31-2015, 12:48 AM
MonsterBilly
MonsterBilly's Avatar
don't try to do blocks in the rear. Purchase 4.5 leaf mid eye rear springs and then do the UCA drop on the front. That should get you there.
It will lower the rear about 3/4 of an inch and the front just shy of an inch. If you want the front lower, you will need to replace or cut the springs.
it is fairly inexpensive and can all be done in a day.
MonsterBilly is offline
Old 07-31-2015, 12:49 AM
MonsterBilly
you cant go much lower because of the 19 inch wheels. lower and you will end up rubbing the tires.
Old 08-03-2015, 10:02 AM
69mach1377
69mach1377's Avatar
I answered in your other post...
69mach1377 is offline
Old 08-04-2015, 05:19 PM
Looks like I will be cutting off 5/8 of a front coil.
Then blocks in the back for now...
Old 08-08-2015, 01:35 PM
Managed to lower the front 1-1/4" and the rear 1"... I think the front might come down another 1/4" after the new springs get broke in a little more. Still need to roll the inside lips in a little farther...
Attached Thumbnails Want To lower my Mustang 1" in rear and maybe 1 1/2" in front-a1.jpg   Want To lower my Mustang 1" in rear and maybe 1 1/2" in front-a2.jpg   Want To lower my Mustang 1" in rear and maybe 1 1/2" in front-r1.jpg   Want To lower my Mustang 1" in rear and maybe 1 1/2" in front-r2.jpg
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
inyadreems
08-21-2015 09:10 AM
MtnMustang
08-16-2015 08:07 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: Want To lower my Mustang 1" in rear and maybe 1 1/2" in front
