Radiator Cap Identification
Old 08-01-2015, 11:03 AM
rma121
rma121's Avatar
Default Radiator Cap Identification
I've got a few radiator caps that I believe are correct for Mustangs. I'd appreciate help identifying the proper application for these caps.
Thanks.
Attached Thumbnails Radiator Cap Identification-397.jpg   Radiator Cap Identification-398.jpg   Radiator Cap Identification-399.jpg
rma121 is offline
Old 08-03-2015, 08:34 AM
bop11
bop11's Avatar
They all say 13# so if they fit they are usable, just different manufacturers. Filler neck depth is 3/4"
bop11 is offline
Old 08-03-2015, 10:27 AM
Mark Hone
Mark Hone's Avatar
The middle one is correct for /66 mustang. M.
Mark Hone is offline
Old 08-03-2015, 05:44 PM
rma121
rma121's Avatar
Thanks for the response. Would you happen to know if the center cap is correct for 66 Mustangs only, or did it come on other years? Also, a knowledgeable friend said the first cap came on 69 & 70 429 Boss Mustangs. Anybody know for sure? There is one on Ebay that appears identical, asking over $1,000.00.
Thanks.
rma121 is offline
Old 08-04-2015, 09:04 AM
Mark Hone
Mark Hone's Avatar
I can only speak for /66 mustangs, but I would bet that it would be O.K. for a year or two either way. M,
Old 08-06-2015, 02:46 PM
barnett468
barnett468's Avatar
there is no such thing as a $1,000.00 rad cap.
there is no reason to run a used 30 - 50 year old rad cap on a car.
buy a new repo cap.
the caps you have are worth around 5 cents.
barnett468 is offline
Old 08-06-2015, 04:32 PM
Mark Hone
Mark Hone's Avatar
There's nothing like having a original /66 rad cap on your car (as long as it's working)
Old 08-07-2015, 08:27 AM
bop11
bop11's Avatar
Barnett is right. Radiator caps do wear out. The relief spring gets either brittle from work hardening or loses all tension. In the first case the radiator pressure can go way up, in the second you lose coolant and the boiling point of the coolant goes down. The gasket at the bottom also goes pad as most are only a modified paper gasket material. If the car is a show car only, keep the original, but if it is a driver or a driver/ show, sooner or later you will have coolant all over that nice looking engine bay.
bop11 is offline
Old 08-11-2015, 02:38 PM
69mach1377
69mach1377's Avatar
Why 13 lb? Will a higher rated one cause damage?
69mach1377 is offline
Old 08-12-2015, 09:43 AM
bop11
bop11's Avatar
Increasing pressure increases the boiling point of the coolant
The boiling point of the coolant is also raised by the concentration of antifreeze.
Adding antifreeze lowers the heat capacity (cooling ability) of the coolant
The engine runs more efficiently when it is hot and the air charge is cold. With a 190° thermostat, some of the coolant will be running much hotter near the cylinder walls. To keep this from vaporizing the coolant, the coolant pressure is increased. This increase comes from the coolant expansion and the air expansion as it heats.
The pressure is a trade-off. A typical radiator is about 20 inches wide and 4 inches deep giving a surface area of about 80 square inches. At 13 psi this is a force of about 1000 pounds trying to push the top tank off and the bottom tank off. Since these tanks are soldered or brazed on we have to keep the radiator cap relief pressure to a safe point where the radiator keeps together but the coolant boiling point is as high as possible. Ford chose 13 psi.
The cap must also allow for air to go back into the radiator as it cools or the radiator and hoses would be sucked flat as the pressure went down. So the cap's ability to hold pressure and leak back are important. Either system can go bad, so it is good to replace the cap periodically.
bop11 is offline
Quick Reply: Radiator Cap Identification
