Big Cam but no lope... - MustangForums.com
Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs (Tech)
Sign in using an external account
Register Forgot Password?
Search
Old 08-23-2015, 06:23 AM   #1
5.0pntydrpr
Vehicle: 1966 Ford Mustang
Default Big Cam but no lope...
Hello all,
I just recently fired up my freshly rebuilt 302. During my rebuild, I installed a comp blower cam: the 284hr blower cam. 35-306-8. The problem which is a relatively small problem, is that the cam doesn't lope enough for my taste. Actually, it seems to lope like my stock cam...
I'm not expecting funny car sound, but I would like a little lope. I do have a quiet exhaust long tubes, h pipe, 2.5 duals to magnaflows (not magnapacks). I plan to install cutouts, so i know that should help some. I'm also on the lean side at idle, but I tuned my carb well to work with the supercharger. Plugs look great.
the Cam should sound similar to this:
Does carburetor tuning have much to do with the sound of the cam lope?
5.0pntydrpr is offline   Reply With Quote
Old 08-23-2015, 08:02 AM   #2
Mustangs of Illinois
Mustangs of Illinois's Avatar
Vehicle: 1968 Ford Mustang
I put a bigger cam in my 302 also, big disappointment as far as a lope goes. But it does run better. If you want a big lope go to http://www.cjponyparts.com and read the descriptions of what it does at the bottom.
I have a bigger cam ordered for my 351W I am building to put in my 68 Mustang and the description of it is ..A mild torque converter will be needed as the camshaft delivers superior high end power and a choppy idle.
__________________
Be sure and come over to Facebook and join us !
Help me complete my Mustang Project, click below...
http://www.gofundme.com/Mustang347Engine
Mustangs of Illinois is offline   Reply With Quote
Old 08-23-2015, 12:25 PM   #3
69mach1377
69mach1377's Avatar
Vehicle: 69 Mach1
IIRC, the comp cams thumper line may provide the sound you want.
__________________
69Mach1 - warmed up 395W (AFR 185s) and Astro A5 with hydraulic clutch, 3.5" Alum DS, 3.50:1 posi, rack&pinion/tilt, 235/50ZR17x8 front & 285/40ZR18x9 rear, American Racing Nova wheels, all MSD, Holley 750, custom paint, headlight relays, Shelby drop & 2" lower all around, Hotwheels Redline scale is 1 to 1.
http://photobucket.com/albums/v618/danaranda/69stang
69mach1377 is online now   Reply With Quote
Old 08-23-2015, 02:31 PM   #4
5.0pntydrpr
Well, my main goal is not sound; it is performance, and so far I've very impressed and am satisfied with the performance of this cam. I have a hunch that my bypass valve may be too small and not bleeding off enough air at idle, so I will be testing it without the supercharged air.
Thoughts?
Old 08-23-2015, 04:23 PM   #5
67mustang302
Vehicle: 67 Mustang Coupe
Technology. Newer cams make better power everywhere and are generally more efficient. Valve timings are improved, overlap is reduced, idle is better etc.
Custom cams go the farthest, some of the newer ones out there actually have emission like specs with wide LSA, but make tons of power.
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
Untested 331, lots of suspension, chewing up corners.
67mustang302 is offline   Reply With Quote
Old 08-23-2015, 07:06 PM   #6
5.0pntydrpr
That's for sure. Technology has come a long way. I'm just still curious why the cam in the video is as choppy as it is, and mine idles as smooth as my stock cam, but we have the same cam grind... The biggest difference that I can see is that one is EFI and mine is carbureted. I just don't understand. The valve opening and closing events should be identical, and that should dictate the sound. Right? Or am I missing something?
Here is another sample video of the EXACT same cam that I have:
Old 08-23-2015, 07:32 PM   #7
67mustang302
Everything else matters too, not just the cam.
__________________
Old 08-23-2015, 09:20 PM   #8
5.0pntydrpr
I understand that. Heads, intake, fuel delivery, immediate exhaust. Correct me if I am wrong (please), but nothing changes the mechanical properties and characteristics of the cam lobe geometry.
My complete setup from air and fuel delivery to exhaust:
Vortech V1 supercharger
Paxton Power hat
Holley 650dp (82651)
Weiand Stealth intake manifold
GT40 iron heads (3 bar)
Ford racing roller lifters
stock push rods and rocker arms (checked the geometry and it was spot on)
Hooker long tube headers with 1 5/8 primaries
2 1/2 inch custom exhaust through magnaflow (not magnapack) mufflers
Tune is still a little lean:
14.1~14.8 at idle
13.9~14.2 at light cruise and moderate acceleration (secondaries still closed)
still breaking in the engine so no boost yet and still below 4K rpms.
Thanks, guys, so far for you help.
Old 08-23-2015, 10:11 PM   #9
67mustang302
Nothing about the cam changes, but airflow does. The lope comes from a certain type of flow through the engine...when you have heads and exhaust that compliment the cam, you can prevent that airflow. The lope then goes away. Also, adding fuel and timing can make lope go away, performance engines tend to want more idle fuel, and more timing helps to stabilize flow at idle speeds, the result is a more mellow idle.
__________________
Old 08-24-2015, 08:04 AM   #10
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Vehicle: 1967 Fastback & 2002 GT Convertible
I like the lope of my Crower. I made this video a few years back after I finished my 351w. Bonus points for Victoria's commentary.
http://vid960.photobucket.com/albums...psupwhhnzx.mp4
Her vehicle recognition skills have improved greatly since then.
__________________
Government Warning:
Governments are extremely dangerous.
Death, imprisonment, theft of property
and loss of freedom will result from
giving them too much power.
fastbackford351 is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Emails Backup
