64 1/2 or 65 help
64 1/2 or 65 help
have seen a convertable vin number 5F08D209275 which suggests it was built in june 64 but it has an alt instead of a gen has 3 speed fan pasanger seat moves door ***** are chrome so from what i have reaserched suggests it is a 65 model and not a 64 1/2 as stated on vin.I am new to all this and it will be my first mustang so PLEASE help
its 50 years old and parts get changed.
look very closely on the drivers side vent **** . . it will have an A on it that might be worn off . . if there is no image of an A, it may have been rebodied.
look inside the trunk at the spare tire hold down bracket . . if it has a small loop instead of a 3" long slot, it is a 66 car.
you need to look under the fener lips for the hidden vin's . . if they are different or not there you my have a problem.
thanks for the reply i have spoken to the dealership and have found out the following.
vin 5F08D209275
Year:
5 1965 (1964 1/2)
Plant:
F Dearborn, MI
Body Series:
08 Convertible
Engine:
D 289 4v V8
Unit:
209275 209275
Miscellaneous Vehicle Data
Body:
76A Convertible, Standard Interior
Color:
J Rangoon Red
Trim:
86 Black Crinkle Vinyl, Standard Interior
Date:
23G July 23, 1964
D.S.O:
41 Chicago
Axle:
1 3.00:1, Conventional
Trans:
6 C4 Automatic
The interior was originally black but has been replaced at some point with the full red set up including carpets and red dashboard.
An Edelbrock 500cfm carburettor has also been fitted with a manual choke to pull some more power from the engine.
There is no A on vent ****, 3 speed fan (not 2) passanger seat moves (i thought it shouldnt) Any thoughts on this would be VERY helpful
vin 5F08D209275
Year:
5 1965 (1964 1/2)
Plant:
F Dearborn, MI
Body Series:
08 Convertible
Engine:
D 289 4v V8
Unit:
209275 209275
Body:
Color:
J Rangoon Red
Trim:
Date:
23G July 23, 1964
D.S.O:
41 Chicago
Axle:
Trans:
6 C4 Automatic
look under the rocker panels . . there will be a date on them unless they have been changed or the number has been bondoed over and post the number for us.
i also suggested you look in the trunk at the tire hold down which you have not done . . if you do not look at these different things, no one can help you.
09-08-2015 02:58 PM
